TODA BUILT
Old Jul 20, 2005 | 08:51 AM
ITR-2001's Avatar
Default TODA BUILT
Modified by ITR-2001 at 7:58 PM 8/8/2006
Old Jul 20, 2005 | 09:03 AM
RagingAngel's Avatar
Default Re: TODA BUILT (ITR-2001)
I'm surprised nobody has told you to search.....
but anyhow....
Your list doesn't even take into account a header, but I am guessing it's going to be a Toda....
If drag racing is all you are after.... I don't think this list is giving you the most for your buck.....
Look up Big Phat R's caR.... his is indicative of what your list would/might produce....
Old Jul 20, 2005 | 09:21 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-2001 &raquo;</TD></TR><TR><TD CLASS="quote"> I also going to have this setup tune by Kingmotorsports...</TD></TR></TABLE>
King Motorsports has some knowledgable and capable in their employ.
I suggest you talk to them, esp. since it seems they will be doing the final "tweaks" on your car.
1/4 mile times and the like are highly variable ...
Old Jul 20, 2005 | 09:32 AM
Big Phat R's Avatar
I have a similar setup on my R. I went with B's - C's will give you more top end which is probably what you are looking for if you are drag racing
You will need larger injectors with this setup. I use 310 cc/min ones. Some have used 440s with great results. I would also recommend a fuel pressure regulator as you will need to increase fuel pressure a bit - either that or you can go with a bigger fuel pump. These cams need lots of gas to get the most out of them.
You will have to play around with the ignition timing a lot to get the most out of the setup. I had a lot of pre-ignition/pinging issues that got sorted out with a good fuel map and timing. You will have to spend a lot of time on the dyno to max these things out.
You should be able to get about 210 whp with B's. More with the C's.
You will also need a 2.5" exhaust system.
The Mugen intake is highly recommended. AEM is
Old Jul 20, 2005 | 09:45 AM
Aquafina's Avatar
Sent you an email.
Old Jul 20, 2005 | 12:28 PM
ITR-2001's Avatar
Thank you guys for quick response I am hoping to have this setup done either before winter or next year after alll the snow melts away.....
Old Jul 20, 2005 | 06:27 PM
Black R's Avatar
25 Year Member
https://honda-tech.com/zerothread?id=1303867
CrX-WoRlD
23
Mar 23, 2007 03:16 PM
Allmota O
10
Feb 10, 2006 07:25 PM
josh green
Dec 27, 2005 07:30 PM
JDM-97CX
May 31, 2004 02:53 PM
MrCrx
Jun 11, 2003 06:51 AM
