how can i know if i need a resistor box?
Old Jul 20, 2005 | 07:36 AM
RACEPAK's Avatar
Default how can i know if i need a resistor box?
hello...
so i got the safc and 450dsm's. how can i know if i need resistor box?
i have a voltmeter, just tell me how to adjust it and what to masure...
best regards m.g.
Old Jul 20, 2005 | 07:42 AM
SOHC_MShue's Avatar
Default Re: how can i know if i need a resistor box? (RACEPAK)
dsm injectors are peak and hold so you need a resistor box. Unless you have a car that already comes with one like an obd0 car.
Old Jul 20, 2005 | 07:46 AM
twisted civic's Avatar
measure the resistance (ohms setting) between the injector connectors, approx 2.5 ohms is low resistance, approx 12.5 is high resistance.
If yours measure around 2.5 then you need resistors or a resistor box.
RACEPAK's Avatar
Default Re: how can i know if i need a resistor box? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">dsm injectors are peak and hold so you need a resistor box. Unless you have a car that already comes with one like an obd0 car. </TD></TR></TABLE>
so actualy every honda needs a resistor box exept obd0?
Old Jul 20, 2005 | 08:55 AM
RACEPAK's Avatar
Default Re: (twisted civic)
ok... i checked the resistance and its 12.2...
so i dont need a resistor box right?
Old Jul 20, 2005 | 09:36 AM
EE_Chris's Avatar
Default Re: (RACEPAK)
No, you do NOT need a resistor box if the injector is coming out to 12.2 ohms.
Old Jul 20, 2005 | 12:40 PM
TunerToys's Avatar
Let's see if I can clear this up....
Your new injector solution must match the resistance of your old injector solution.
- If your stock injectors are low impedance (2-4Ohms) and your new injectors are low impedance, then you are good to go.
- If your stock are high impedance (10-12Ohms), and your new injectors are low impedance, then you need resistors.
- If your stock injectors are low impedance, and your new ones are high, you're out of luck. Buy some low impedance injectors.
Some basic info
- Low Impedance = 2-4Ohms = Peak And Hold
- High Impedance = 10-12 Ohms = Saturated
- OBD0 Hondas have both low and high impedance injectors in MPFI (1988 - 1991) Most often, Si models haev low impedance, and other models have high impedance.
- OBD1 Hondas have high impedance injectors with a plug that matches OBD0 injectors, no swapping of plugs needed.
- OBD2 Hondas have high impedance injectors, with a plug that must be swapped for aftermarket injectors.
Checking existing injector impedance is as easy as disconnecting the plug, and measuring across the terminals in the injector connector. Use the lowest resistance setting of your meter, normally 300 or 200 Ohm range. Polarity will not matter.
Use this link to see some directions we have published for our customers looking to buy CorrectInjects. http://stores.ebay.com/Tuner-T....html
Hope that helps...
Craig
birz
Jun 21, 2006 05:02 PM
ferio 95
Oct 2, 2004 07:12 PM
Mr_Bojangles
Jun 18, 2004 09:07 AM
redboost10
Oct 23, 2003 03:35 PM
