My Turbo GSR Pics
Old Jul 20, 2005 | 07:33 AM
bigdgsr's Avatar
Default My Turbo GSR Pics
Finally finished the turbo install!!! Heres some pictures of the car:
Final Mod List:
-SFP Turbo Manifold (Still have AC & PS)
-SFP 2.5" Downpipe
-2.5" Test Pipe
-Garrett T3/T4 60 Trim .63 A/R Turbo
-9 LBS of Boost
-2.5" Straight-thru Exhaust
-Tial 38MM Wastegate
-2.5" IC Piping
-Johnny Racecar IC
-HKS SQV BOV
-ITR valves, springs, and retainers
-3-Angle Valve Job
-ITR Cams
-Skunk2 IM
-ITR TB
-Cometic Turbo Headgasket (9.5:1 Compression)
-Nuformz Block Guard
-ARP Headstuds
-JDM Valve Cover
-STR Cam Seal Plug
-Skunk2 Cam Gears
-Greddy Timing Belt
-MSD Blaster Coil 2 (Not installed)
-AEM Fuel Rail
-Ford/Bosch 440cc Injectors
-B&M FPR
-ES Motor Mount Inserts
-Greddy 60MM EGT Gauge
-Automer 52MM Sport Comp Boost Gauge
-Greddy Profec Spec II Boost Controller
-JDM ITR Gauge Cluster
-Autometer Cobalt Tach & Shift Lite
-OBDIIB to OBDI conversion harness
-P28 OBDI ECU
-Tuned by PHIZ with crome pro (Street Tune)
Modified by bigdgsr at 4:55 PM 7/20/2005
Old Jul 20, 2005 | 07:40 AM
SOHC_MShue's Avatar
Default Re: My Turbo GSR Pics (bigdgsr)
It looks nice, but you need to resize your pics and take them less blurry . Any numbers yet or was this just a street tune?
Old Jul 20, 2005 | 07:41 AM
CRX T-Si's Avatar
ya..need to resize them pics man.
Old Jul 20, 2005 | 07:42 AM
EJ1 wilcox's Avatar
Looks nice...
But those pictures are soo huge I really couldn't see much of it.
I can only fit about a 5th of each picture on my screen at a time.
Old Jul 20, 2005 | 08:05 AM
D-tuned's Avatar
Default Re: My Turbo GSR Pics (EJ1 wilcox)
nice any numbers
Old Jul 20, 2005 | 08:10 AM
bigprospect187's Avatar
Clean as hell man. Looks like the FMIC is gonna eat you.
Old Jul 20, 2005 | 08:11 AM
CRX T-Si's Avatar
Default Re: My Turbo GSR Pics (CRX T-Si)
Man..I love your I/C that new Johnny I/C is awesome.
Benjithx's Avatar
Default Re: My Turbo GSR Pics (2000civicsi)
you had it tore down and didn't build the bottom end?
Looks really good though man
...block guard
Old Jul 20, 2005 | 08:21 AM
FredoSP's Avatar
Default Re: My Turbo GSR Pics (Benjithx)
nice pics
Old Jul 20, 2005 | 09:15 AM
bostoncal's Avatar
Default Re: My Turbo GSR Pics (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">nice pics </TD></TR></TABLE>
Old Jul 20, 2005 | 09:46 AM
11psiTurboSI's Avatar
Default Re: My Turbo GSR Pics (Este_Cara)
Looks good!
Old Jul 20, 2005 | 10:31 AM
darkdayz's Avatar
clean set up..
Old Jul 20, 2005 | 02:34 PM
Rod.'s Avatar
Default Re: My Turbo GSR Pics (darkdayz)
Old Jul 20, 2005 | 02:38 PM
B18 WES's Avatar
Default Re: My Turbo GSR Pics (SOHC_MShue)
looks nice, good job man.
Old Jul 20, 2005 | 02:42 PM
mike1114's Avatar
Default Re: My Turbo GSR Pics (B18 WES)
If I can give a warning, keep an eye on the turbo to manifold bolts, they will most likely back out over time. Some lockwashers, longer bolts with nuts on the opposite side and loctite will do the trick.
I know the bolts screw into the manifold, but if you nutted them on top as well you will not have any problems.
I speak from experience.
Hehehe, I also said nutted!!!! sorry, just had to chuckle at it.
Old Jul 20, 2005 | 03:51 PM
adseguy's Avatar
Default Re: My Turbo GSR Pics (mike1114)
clean setup. I really like that intake manifold
Old Jul 20, 2005 | 05:28 PM
JDMs1eeper's Avatar
Nice car man!
Old Jul 20, 2005 | 05:49 PM
BoostedEG6's Avatar
Default Re: My Turbo GSR Pics (adseguy)
I like the intake manifold
Old Jul 20, 2005 | 06:21 PM
spoolingb20's Avatar
Is your dump tube re-routed into your down pipe? If not why didnt you just run it stright down?
Looks really good though, the mani looks real fresh!
Old Jul 20, 2005 | 06:49 PM
Turbocivic94's Avatar
Default Re: My Turbo GSR Pics (spoolingb20)
Nice setup and nice looking car
Welcome to darkside
Old Jul 20, 2005 | 07:49 PM
60-1teg's Avatar
Default Re: My Turbo GSR Pics (Turbocivic94)
Old Jul 20, 2005 | 08:16 PM
WillieWillieFast's Avatar
Clean
Old Jul 20, 2005 | 08:38 PM
gritsak's Avatar
Default Re: My Turbo GSR Pics (WillieWillieFast)
dump tube looks pretty close to the a/c line. might want to put some heat wrap around the tube just in case.
Old Jul 20, 2005 | 09:03 PM
Bms212's Avatar
Default Re: My Turbo GSR Pics (gritsak)
looks good . make sure u post some numbers
Old Jul 20, 2005 | 09:24 PM
H.A.R.T B18C1EG6's Avatar
Default Re: My Turbo GSR Pics (Bms212)
