NEED HELP want both fans to turn on with manual switch(CRX with LS swap).
I just put an LS swap in my CRX the fan doesn't seem to be turning on. I made sure the fan itself worked by attaching it to the battery and it does. Im thinking of making a switch that turns on both condensor and radiator fan on( i have no AC). Does anyone have any suggestions on getting the fan working or how to make the switch?
unplug the 2 wire fan switch from the back side of the engine (it will consist of a rubber boot covering 2 female banana-type plugs) and jumper them together. If the fan turns on while the ignition is on, then your wiring is up to par and the switch itself is bad.
to make the fans come on with a switch, wire a switch up to the two terminals. each terminal of a SPST switch to a fan switch plug wire.
Lloyd Xmas
Apr 14, 2010 09:21 AM
