GSR brake swap- into eg hatch
Old Jul 20, 2005 | 03:19 AM
ArtNerd's Avatar
Default GSR brake swap- into eg hatch
i was wondering- what size rotors does a GSR have up front? I am doing a rear disc swap in my 94 hatch, and was wondering if i should swap out the fronts as well? is it really that much more stopping power? Any difference in Calipers?
Old Jul 20, 2005 | 04:18 AM
azn6915's Avatar
Default Re: GSR brake swap- into eg hatch (j-D-m)
i think that the front GSR are 10.1 where your hatch is 9 some thing. if you are going to do a break swap then you might as well do the whole 9. front and rear brakes, booster, master cylinder, and proproation valve. just my .02 cents.
Old Jul 20, 2005 | 04:57 AM
94hatchling's Avatar
Default Re: GSR brake swap- into eg hatch (azn6915)
i noticed a difference in mine when i upgraded the front. but i also upgraded the rotors to. so not sure if it was the upgrade in itself, or the rotors, or just a combo of both.i love it, that little car stops on a dime now.
Old Jul 20, 2005 | 08:06 AM
dc2vu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-D-m &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering- what size rotors does a GSR have up front? I am doing a rear disc swap in my 94 hatch, and was wondering if i should swap out the fronts as well? is it really that much more stopping power? Any difference in Calipers?</TD></TR></TABLE>
i forget what size rotors i beleive its 10.2...yes you should do fronts aswell, yess makes a difference for stopping power...caliper is a lil bigger with gsr
Old Jul 21, 2005 | 02:55 AM
ArtNerd's Avatar
Default Re: GSR brake swap- into eg hatch (dc2vu)
Thanks- for the replys! Now i have the proportion valve- fronts rears, and new Master cylinder- Someone above said i waould also have to replace the bosster? Is that true?
Old Jul 21, 2005 | 02:58 AM
BlueIntegraBoy's Avatar
Im going to put my brake conversion on my EG this weekend. The Integra rotors are 10.3" btw. There's no need for a booster if you are using a Civic 15/16" MC. If you are using an Integra RS MC, you'll need that booster. The Integra calipers have a larger piston than an EX with 10.3" rotors. So it's better than a regular hatch caliper.
Old Jul 21, 2005 | 07:15 PM
ArtNerd's Avatar
Default Re: GSR brake swap- into eg hatch (BlueIntegraBoy)
anyone have the part # on the booster?
L1lKraYzi3
Suspension & Brakes
15
Sep 6, 2012 02:58 PM
97civic94gsxr
Aug 1, 2008 07:57 AM
TheTealHatch
11
Feb 26, 2006 10:27 AM
98silverhatch
11
Sep 26, 2002 05:14 AM
