Upper control arm problem?
Old Jul 20, 2005 | 02:51 AM
G2integra217's Avatar
Default Upper control arm problem?
Ive been having a weird vibration while acceleratin in my 90 dx hatch. It goes away time to time. Its coming from the left side. I took off the tire and on the upper the bushing looks shot and like blown out. I was pullin at the joint and it seems very loose if I sqeeze the bushing together tightly it tightens it up and its not as loose. I was wondering if this is causin the vibration and also can I just replace the bushing or the whole upper arm?
Old Jul 20, 2005 | 12:50 PM
Default Re: Upper control arm problem? (Dropdhatch217)
bump
Old Jul 20, 2005 | 12:55 PM
Tyson's Avatar
if its loose, then it should be replaced.
you can buy the bushing separately from honda. $12 each.
Old Jul 20, 2005 | 03:58 PM
Also some more probllems. It seems that the tire is wearing quickly. Both front tires. The left more then right. At higher speeds the car tends to pull back n forth like almost causing loss of control. The Vibrating only happens when acceleration. When I push the clutch it it goes away. The way the tires are wearing is kinda like camber were but the cars only lower like 1.5 inches and theres hardly camber. This is my 3 rd lowered car and my last car was 3 inches lowered with a lot of camber and the tires barely wore. Can someone helps me out? Tell me the main things to check?
Old Jul 20, 2005 | 04:04 PM
Tyson's Avatar
Default Re: (Dropdhatch217)
dude, if you bushing is broken, fix it.
your car sounds dangerous to drive. what are you waiting for?
Old Jul 20, 2005 | 04:19 PM
Default Re: (Tyson)
well I put a new bushing it in and it doesnt vibrate anymore. and its not loose. But what about the other problems... One bushing is gonna cause all this?
Old Jul 20, 2005 | 04:26 PM
Tyson's Avatar
fix one thing at a time.
Old Jul 20, 2005 | 04:34 PM
Default Re: (Tyson)
No I put the bushin in now what do I fix? Its still loose in steeing at higher speeds and I dont want the tires to wear anymore. Should I just take it to a shop tomorro and ask them to check it out or adjust toe or something?
Old Jul 20, 2005 | 04:36 PM
Tyson's Avatar
its really hard to understand what problems you are now describing. i barely caught that you even replaced the bushing already.
badly aligned toe causes tire wear. it would be a good idea to align it.
have you checked the tie rods? feel any play in the wheels when you push them?
Old Jul 20, 2005 | 04:45 PM
Not really any play. My Integra needed tie rods but never caused any problems it had a lot of play in it and never caused tire wear and it handle like 150% better then this car.
Old Jul 20, 2005 | 04:49 PM
Tyson's Avatar
get it aligned then.
play in your balljoints will cause handling and tire wear issues.
sd619jef9
17
Nov 25, 2011 01:41 AM
patpatjacky
Jun 12, 2007 08:06 PM
CRX 2.0V-T
Dec 19, 2006 12:00 PM
Nitto
15
May 9, 2004 08:23 PM
