Suspension & Brakes Theory, alignment, spring rates....
To replace front lca bushings with es bushings or not to replace?
Old Jul 20, 2005 | 12:12 AM
Bay_707's Avatar
Default To replace front lca bushings with es bushings or not to replace?
I think my front lca bushings are going bad but im not sure... well atleast on the left side, because it feels like my shocks is bottoming out, but it feels more like the lca hitting something. Anywho, i figured they are old anyways, 10 years old, and i thought about replacing them with the energy suspension bushing kit for like 40 bucks since it will handle better and might fix the problem.
My only negative thoughts holding me back are.... how long of a life would these bushings have? Do they squeak like everyone says they do? how rough is the ride? Is it worth buying if i had to replace the bushings?
The problem with the lca hitting (or something else hitting im not sure) started right when i did my 5 lug conversion, its whenever i turn to the left and take a turn fairly hard or sometimes just take a normal left turn.
THANKS!!!
Old Jul 20, 2005 | 10:08 AM
Bay_707's Avatar
hmm
Old Jul 20, 2005 | 12:03 PM
808_si's Avatar
i don't know if this will help, but I just replaced my swaybar and endlink bushings on my tacoma with ES bushings. It made a pretty big difference and improved ride quality.
I was rushing on the install, and after I bolted everything back up i was really nervous that I didn't lube them up enough. I haven't heard any squeeks at all though. hope that helps.
Old Jul 20, 2005 | 08:18 PM
Bay_707's Avatar
thanks any input definately helps!
Old Jul 23, 2005 | 05:00 PM
Bay_707's Avatar
up.
Old Jul 24, 2005 | 08:50 AM
Sobe_Death's Avatar
how low is the car?
Old Jul 24, 2005 | 11:43 AM
Bay_707's Avatar
i believe its about 2.5" lowered from stock
Old Jul 24, 2005 | 07:41 PM
Sobe_Death's Avatar
it could quite possibly be the upper control arms hitting on the frame rails inside the fender. check that out and see whats up.
emr88
Feb 20, 2011 05:29 PM
thumper64
Mar 13, 2009 11:19 AM
The Internet Tough Guy
Oct 25, 2003 07:47 PM
Oct 25, 2003 11:43 AM
J-g-D-s-M-r
Oct 8, 2002 06:46 PM
