NEED HELP with engine wiring 94 integra ls into 98 civic with HX engine wiring need diagram
Old Jul 19, 2005 | 11:06 PM
greddydc5's Avatar
Default NEED HELP with engine wiring 94 integra ls into 98 civic with HX engine wiring need diagram
How you guys doing i'm trying to do my swap which is a 94 integra ls into a 98 civic with a HX engine harness I have everything to do the swap and my friends said they can do it for me but they said they need a engine wiring diagram please help me i also have the 94 ls engine harness but i was told to use the HX because it will be better and also because i wont have v-tec im using the 94 ls ecu with the jumper harness convertion so i can tune it
please help me THANKS P.S. im using a HX wiring harness for the swap please help me you can email me at SIMON1TN@MSN.COM please help me get the diagram so i can drive my car it's been months THANKS
also please dont mind im under my brothers name he has the dc-5 i have the EK
T N . . . also our TN... type R is for sale
Old Jul 20, 2005 | 05:05 AM
nasteboyii's Avatar
Default Re: NEED HELP with engine wiring 94 integra ls into 98 civic with HX engine wiring need diagram (gr
dude, here is the deal, the easiest thing for you to do is find any other harness besdies the HX to put that swap in iyour car, and what year car is it goin in, i assume obd2, if that is the case and if u are tryin to run a obd1 ecu, either u going to have to use a obd1 ecu/w/obd2 jumper wire, or u have to rig up the oil/crank sensor for the obd2 ecu.
basically what im sayin is if its obd2 car it has to use obd2 harness NOT HX (since hx does not use the standard 4 wire o2, it uses a special wideband 5 wire, even though its 8 plug connector) i know ive done this before NEVER EVER Got the hx harness to run the car right, becuase there is more then one set of wires that are diff but only on the HX all other harnesses will work
i hope this helps
dan
Old Jul 20, 2005 | 05:12 AM
greddydc5's Avatar
thanks so you mean run any other wire except HX got ya yea it's going in a 98 civic do you know where i can get the engine wiring diagram
Old Jul 20, 2005 | 06:40 AM
j.ro's Avatar
ok, what you are going to have to do is get an ex harness then splice the plugs from the ls dizzy, alt and iat on to the ex harness. then you will have to extend your primary o2 sensor wire and you should be good... if i remember anything else i'll post up later..
a helms would help...but you can do it with the 92-95 haynes and the 96-00 haynes.
you will need both manuals to match up the wires for the dizzy....
Modified by drklver at 10:58 AM 7/20/2005
Modified by drklver at 11:20 AM 7/20/2005
Old Jul 22, 2005 | 04:12 AM
nasteboyii's Avatar
what he said about sums it up , just whatever you decide dont use the hx,
good luck man, if u need anything else, hit me up on here, i got parts or information
dan
greddydc5
Jul 20, 2005 12:35 PM
shorty0o29
Jan 5, 2005 08:48 PM
myDC4rox
Dec 15, 2004 12:23 AM
94Acura
Sep 15, 2004 11:02 AM
