68mm s2 tb?
Old Jul 19, 2005 | 09:30 PM
nolimitlex's Avatar
Default 68mm s2 tb?
tried searching but not much found.
question: 68mm skunk 2 tb worth 275$ for my setup or no?
setup:
b16 w/ ctr intake cam
4-1 dc sport headers / catback
s2 im
Old Jul 19, 2005 | 10:47 PM
Icey112's Avatar
Default Re: 68mm s2 tb? (nolimitlex)
send your stock one to maxbore he does good work for $100. he can bore it bigger then type r.
Old Jul 20, 2005 | 12:35 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolimitlex &raquo;</TD></TR><TR><TD CLASS="quote">
No, not worth it.
Old Jul 20, 2005 | 08:39 AM
iakona's Avatar
nope. either get the stock one bored out, or spend that same amount of bread on a good 70mm/72mm.
Old Jul 20, 2005 | 05:21 PM
Pondus's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">nope. either get the stock one bored out, or spend that same amount of bread on a good 70mm/72mm.</TD></TR></TABLE>
What's your reasoning for going even bigger when a 68mm TB already is too big for this setup? Getting the stock one bored out a couple of mm's i plenty for a 1.6liter setup.
Old Jul 20, 2005 | 07:00 PM
iakona's Avatar
no special reasoning. just more air. let the engine breathe a bit better. yes, some think it's overkill.
but yes, you're right, a 68mm will work just fine. they all cost the same though, so why not get a bigger one if you can tune for it?
Old Jul 21, 2005 | 12:18 PM
N_A_is_best's Avatar
the skunk one isnt not very good anyway i have seen at least 5 of these just hang open... on numerous accounts i recommend just having the stock one bored out or buying a type r or jg edelbrock one
james
Old Jul 21, 2005 | 03:10 PM
RedEj8's Avatar
Yea i think the Maxbore would be the way to go..I believe he can bore it out to 64mm which is plenty for a b16.He can also portmatch ur IM if its not already bigger.
Old Jul 21, 2005 | 10:45 PM
Icey112's Avatar
Default Re: 68mm s2 tb? (reddohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Yea i think the Maxbore would be the way to go..I believe he can bore it out to 64mm which is plenty for a b16.He can also portmatch ur IM if its not already bigger.</TD></TR></TABLE> he can make your b16 2mm bigger then a type r . very good work
COLIMA0003ITR
Jun 25, 2008 09:06 AM
prelude_93vtec
Jun 25, 2007 04:03 AM
porter
Jan 9, 2007 03:27 PM
kornerk12
Sep 23, 2006 07:20 AM
yeegsr
Oct 11, 2004 11:47 PM
