What backspace for 13 inch weld import magnum
Old Jul 19, 2005 | 07:57 PM
integraboosted's Avatar
Default What backspace for 13 inch weld import magnum
I have a 97 Integra what backspace do you guys recommend 4 inch or 5 inch backspace thanks.
Old Jul 29, 2005 | 09:18 PM
Default Re: What backspace for 13 inch weld import magnum (integraboosted)
Anyone?
Old Jul 30, 2005 | 09:11 AM
DaveF's Avatar
3.5 or 4 inch backspace should be ok.
Old Jul 31, 2005 | 04:55 AM
Default Re: What backspace for 13 inch weld import magnum (Dturbocivic)
5 inch bakspace too big or ok?
Old Jul 31, 2005 | 06:19 AM
DaveF's Avatar
your wheel might hit the spindle...
use a tape measure.
Old Jul 31, 2005 | 11:47 AM
delslowh23's Avatar
will the 13" fit over the gsr braks?
Old Jul 31, 2005 | 11:49 AM
Whats a spindle? im using 1/4 inch wheel spacers.
Modified by integraboosted at 1:20 PM 7/31/2005
Old Jul 31, 2005 | 01:46 PM
1700anddroping's Avatar
Default Re: What backspace for 13 inch weld import magnum (delslowh23)
no they will not.....i have tried this.....you have to grind the **** out of your caliper
and believe me it is to close for comfort.
harv
Old Jul 31, 2005 | 03:25 PM
delslowh23's Avatar
Default Re: What backspace for 13 inch weld import magnum (1700anddroping)
ever if i run a 1/4" spacer?
Old Jul 31, 2005 | 03:27 PM
don't know about that one.only one way to find out tho.surely the spacers cain't be that much.
harv
Old Jul 31, 2005 | 03:31 PM
delslowh23's Avatar
yea but the wheels are iam scared lots of money
Old Jul 31, 2005 | 03:34 PM
what wheels are U running?
Old Jul 31, 2005 | 03:40 PM
how fast do you plan on running.i will eventually sell these and go w/15's because of the power i will be mahttps://honda-tech.com/zerothread?id=1282519king....here is a pic of them.
harv
Old Jul 31, 2005 | 03:45 PM
https://honda-tech.com/zerothread?id=1282519 sorry about that.don't know why it didn't take.
harv
Old Jul 31, 2005 | 04:34 PM
AMS MIKE's Avatar
5" backspacing will work perfectly! That is what I ran on my 13x8 Bogarts
Old Jul 31, 2005 | 04:36 PM
Default Re: What backspace for 13 inch weld import magnum (AMS MIKE)
i suppose you run the gsr brake set up correct.i just have the stock civic brake cailpers for now.i will be selling mine and going w/15" for the power i will be making.
harv
Old Jul 31, 2005 | 04:46 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">i suppose you run the gsr brake set up correct.i just have the stock civic brake cailpers for now.i will be selling mine and going w/15" for the power i will be making.
harv</TD></TR></TABLE>
from experience with 13" drag wheels...
4" will ONLY clear stock civic brakes (NOT SI or GSR or LS brakes)
5" will clear all OEM Honda/Acura 4lug and 5lug brakes (will not clear big brakes)
Old Jul 31, 2005 | 05:02 PM
i will look at mine tom and see.but i do not think mine has any spacing.but i could be wrong.i will look tom tho?
harv
Old Jul 31, 2005 | 05:58 PM
delslowh23's Avatar
the spindle is the pice that holds the rotor and brakes
Old Jul 31, 2005 | 06:36 PM
AMS MIKE's Avatar
my custom bogarts w/ 5" spacing
Old Jul 31, 2005 | 06:51 PM
delslowh23's Avatar
are thoes 13x8
Old Jul 31, 2005 | 07:04 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowh23 &raquo;</TD></TR><TR><TD CLASS="quote">are thoes 13x8</TD></TR></TABLE>
YES
Old Jul 31, 2005 | 07:10 PM
DEMNTD1's Avatar
I also run a set of Bogarts. The GSR front brakes just clear. Mounted and examined. Only thing is that when I have it balanced, I have them use the thin stick on weights and not the large weights. I believe spacing is 5" too.
Old Jul 31, 2005 | 07:18 PM
delslowh23's Avatar
Default Re: What backspace for 13 inch weld import magnum (DEMNTD1)
ok I guess 5" back spaceing is ok. Going to order the 13x8 wheels and boy i hope they work thx for all the info. I think iam going with the 24.50 x8 13
Old Jul 31, 2005 | 07:19 PM
delslowh23's Avatar
o one more think tubes or no tubes?
