FS: turbos, oem stuff, type r girdle setup, greddy flange + more
USED type r oil pan, used gasket, windage, pickup, mains/bolts, bottom end girdle ..will fit any b16/b18. great for strengthening up block. im not using it due to change of plans. i cant find the windage tray right now, but i know i have it ($200 obo)
USED oem 86 crx hf half radiator.. bought it used about 2,000 miles ago. great condition. will also throw in a new radiator cap. im not using this anymore because i bought a thicker radiator. ($50 obo)
USED 300zx turbo ..minor shaft play. bought it from ebay, but never got to use it. .60 cold side, not sure of hot side. not using this because i went with the ford turbo instead ($100 obo)
USED 85 svo/merkur/thunderbird turbo.. had it on my car for about 2,000 miles. has a bit of shaft play. it didnt smoke after i put the correct oil restrictor on my car. you can rebuild it if you want, but works fine as is. will come with some misc water fittings and a brand new cold side housing. this added a ton of power...48 hot/.60 cold. selling this because i got my hands on a new turbo for cheap.
($100 obo)
NEW greddy weld-on blow off valve flange ($25 obo)
USED eclipse non turbo 240cc injectors ($20 obo)
tons more stuff to come... ill try to upload pics soon
($100 obo)
integcraze
Oct 16, 2007 12:09 AM
FS: CRX FULL SIZE Fluidyne Radiator Spoolin Downpipe B16 tapped oil pan NIB Alpine CDA-9853 GSR inje
98B18C1
Aug 5, 2005 07:18 PM
staticchmbr
Jul 20, 2005 07:28 AM
