Factory Radio/AC unit not backlighting.
Hi all, I'm trying to get some help with my factory radio and AC unit. I have a 2003 4 cyl. 2 door accord, and the backlighting on the unit went out. All the functions work fine and the LCD display is working as well, it is just not backlit.
Is this a common problem? I have an aftermarket HU but I checked and rechecked all wires and they are fine( the problem happened many months after the HU install). I also checked all fuses. I just know there is a hidden fuse or wire somewhere I am overlooking. I even took the unit apart down to the PCBs but couldn't find a fuse.
Help!
Thanks
Help!
Thanks
check with your honda dealer,we have a service bulletin pertaining to that problem,if you are under warranty,if not, they can replace under the goodwill policy.
Thank you so much, I never would have known there was a recall. Unfortunately, my car is rebuilt so not under warranty.
Is there any way to get some details about this bulletin?
Thanks!
Thanks!
pro1911
Jun 29, 2024 09:52 AM
dc2jdmteg05
Jul 20, 2005 12:37 PM
