03 accord- Factory radio/AC unit not backlit!
Old Jul 19, 2005 | 03:16 PM
hypo's Avatar
Default 03 accord- Factory radio/AC unit not backlit!
Hello all! This is my first post here. I used to be an avid speedfreak with a 91 TT 300zx, but now I have a 2003 4 cyl 2 door accord. It is a fun car, and as car audio is my passion, I've already installed a sound system.
Anyway, everything worked fine for several months after the install, then one day the entire radio/AC dash unit would not backlight. It doesn't matter if the headlights are on or off, the backlight for the crystal display and audio function buttons is not working. The entire unit is, however, working fine. I can still do all the AC functions and play with the (disconnected) factory radio, I just can't see anything on the display. It should also be noted that the LED AC lights along the bottom button row do light when pressed, it is just the backlighting funtion which seems to be malfunctioning.
I hope this is a fixable problem! I've already checked the fuses in the under-dash and under the hood, they all look fine.
Help, i need to see my display!
Thanks!
fredb922
Nov 10, 2015 01:08 PM
hypo
Jul 20, 2005 09:53 AM
CheeseKT
Jun 16, 2005 11:13 PM
mnm99
Apr 23, 2005 07:21 AM
