Jackson racing supercharger with stock intake??
You might not be able to use the stock intake without modification. The supercharger changes the angle of the throttlebody, so if you wish to use the stock intake you'll probably need to do some cutting.
When I installed mine, the position of the throttlebody was altered enough that my AEM CAI didn't fit, and I had to cut a portion of it off, then use the tube that JR gives you to make it work. I've since ditched the AEM portion of the intake and use the AEM filter with the tube JR gives you. It's a great fit, although if I remember correctly the diameter is only 2.5 inches.
Like this:
Like this:
