help building a engine will ctr pistons fits on ls rods
Old Jul 19, 2005 | 01:22 PM
REEMB18C1's Avatar
Default help building a engine will ctr pistons fits on ls rods
im looking to go high compression ls and in i have a set of b16 pistons but the area where the piston pins go were damage i wanted to know if any has ever had ctr pistons on ls rods
Old Jul 19, 2005 | 01:27 PM
Supernatural's Avatar
Default Re: help building a engine will ctr pistons fits on ls rods (REEMB18C1)
you have to shave the small rod ends or the pistons to make the combo fit
Old Jul 19, 2005 | 03:28 PM
zCivic's Avatar
Default Re: help building a engine will ctr pistons fits on ls rods (SUPERNATURAL)
yup and you take 1mm of each side.. works like a charm
Old Jul 19, 2005 | 03:43 PM
REEMB18C1's Avatar
Default Re: help building a engine will ctr pistons fits on ls rods (zCivic)
a machine shop has to do that correct and if i use arp rod bolt do i have to resize my rods?????
Old Jul 22, 2005 | 06:59 PM
zCivic's Avatar
yeah I would suggest a machine shop strongly. You dont need to have your rods resized for the ARP rod bolts. You need the 8mm ones, to be on the safe side you may want to have those installed prior to getting the small end milled and have them check the big end for out of round. This would save you time in the long run
EgK2o09
Feb 1, 2010 06:29 PM
k24a4kid
Oct 9, 2005 02:55 PM
na_lseg
Sep 1, 2005 01:53 PM
fox297
Aug 4, 2003 12:39 PM
arw321
Jun 20, 2003 11:26 AM
