Suspension & Brakes Theory, alignment, spring rates....
Ex brakes onto my cx
Old Jul 19, 2005 | 12:58 PM
spoonef's Avatar
Default Ex brakes onto my cx
Oka so im pulling the brakes off a 93 ex coupe and putting it on my car(ex coupe auto with front discs only).Is this striaght forward job? also the knuckles on the drivers side are fucked and i was wondering if i can use my stock civic knuckles and just swap over everything else
Old Jul 20, 2005 | 11:19 AM
89efeight's Avatar
Default Re: Ex brakes onto my cx (spoonef)
http://hybrid2.honda-perf.org/tech/4g-brakes.html check that out. that's the correct way to do it without any problems what-so-ever! i think there will be camber issues and clearence issues with the upper control arm hitting the chassis if you use the EG stuff. hope it helps..peas
Old Jul 21, 2005 | 12:44 AM
spoonef's Avatar
Default Re: Ex brakes onto my cx (89EFeight)
damn so all civic knuckles are not the same?
Old Jul 21, 2005 | 01:15 PM
spoonef's Avatar
the brakes will be going onto my 1992 cx
Old Jul 21, 2005 | 01:54 PM
Tyson's Avatar
knuckle part numbers seem to be different from the EX (92-95) to CX (92-95). i would check the brake caliper spacing to see if it fits. also if the rotors are different size. im guessing thats the difference.
Old Jul 22, 2005 | 12:15 PM
spoonef's Avatar
Default Re: Ex brakes onto my cx (Tyson)
can anyone else confirm
Old Jul 23, 2005 | 09:55 AM
egsleepercivic's Avatar
the calipe mounting points are different from the ex to the cx, just look at them on the ex they stick out further to accomodate the larger rotors
J_Marc
Suspension & Brakes
Oct 10, 2007 08:14 PM
goforbroke
May 5, 2006 11:45 AM
ROOROWNS
Mar 20, 2005 08:49 PM
gato5254
Aug 25, 2004 06:14 AM
