h22 front motor mount, how vital? 4th gen
Old Jul 19, 2005 | 11:37 AM
lildrgn2.0's Avatar
New User
Default h22 front motor mount, how vital? 4th gen
Ok, my turbo has forced me to remove my front motor mount. How vital is this one mount? I have seen hatches run with out since they dont have a way to mount it to anything. But I am just curious if any 4th gen has removed it?
Old Jul 19, 2005 | 12:07 PM
PrecisionH23a's Avatar
Default Re: h22 front motor mount, how vital? 4th gen (Lildrgn)
civics use much stronger mounts than the stock preludes one have. hasports use 70mm and i think 80mms urethane mounts which provide enough shock absorbtion to not allow the motor to flex like it does in a prelude with no front mount. i made a custom tube frame mount for mine a few yrs back. i dont recommend running without the front mount... simply rev the engine at idle and youll be shocked at how much it flexes.
Old Jul 19, 2005 | 01:12 PM
Eddiebx's Avatar
yeah, u cant rely on the other 3 mounts, because only one of them is actually a torque mount, the two side mounts hardly provide any support against the engine twisting.
Old Jul 19, 2005 | 01:21 PM
Shakes's Avatar
space cadet
Default Re: (Eddiebx)
make a solid rear mount and you should be fine. just add it to your list of items to check up on every time you change your oil.
its not like the engine will come flying out of the car when you hit Veee TAAAAKKKKK!!!!!!!!!!!! y0
Old Jul 19, 2005 | 01:59 PM
cpforyou's Avatar
Default Re: (Shakes)
I once ran on three mounts to be able to run the Prospeed Header.
Withing a couple months, one of the stock motor mounts went bad.
Old Jul 19, 2005 | 02:55 PM
lildrgn2.0's Avatar
New User
Default Re: h22 front motor mount, how vital? 4th gen (PrecisionH23a)
well, the entire mount has to come out for everything to fit right. The oil drain for the turbo also lands right smack dab on it.
So, get a solid rear mount? and stronger side mounts?
any recommendations? Or should I try to find a different manifold?
Old Jul 19, 2005 | 03:39 PM
DJ_SaNdOz's Avatar
different manifold seems easier to me
Old Jul 19, 2005 | 03:46 PM
SKDRCR's Avatar
Default Re: h22 front motor mount, how vital? 4th gen (DJ_SaNdOz)
If you decide to run w/o the front mount, I would get es motor mount inserts
for the other 3 mounts.
Old Jul 19, 2005 | 06:04 PM
PrettyLude's Avatar
you will definately have to run that mount, i was stupid and tried it without the front mount, and endedup shattering the driver side mount, which cost me 80 bux to get
Old Jul 20, 2005 | 04:33 AM
lildrgn2.0's Avatar
New User
Any one else running the moroso oil pan? I think that is causing me the most trouble. Because the hole for the line is right there behind the mount. If I put a 45 deg angle on it, I might be able to get around it.. I dont know.. I would hate to get a new manifold over one damn drain line.
Old Jul 20, 2005 | 06:06 AM
Default Re: (Lildrgn)
weld on a new -10an bung.
duh.
Old Jul 20, 2005 | 06:19 AM
lildrgn2.0's Avatar
New User
Default Re: (PrecisionH23a)
me weld?
Yea, I will probably end up taking off the pan and having some one weld a new bung in a not so annoying location.
It just sucks that i worked so hard to have the car ready for this weekend, and stopped by a drain plug location. /sigh
Old Jul 20, 2005 | 01:48 PM
You can have it done in a days work if you get off of honda-tech and bust your ***
saemoonyang
11
Nov 3, 2011 12:33 PM
es_squared
Jan 27, 2009 07:22 PM
lildrgn2.0
May 2, 2007 07:44 AM
BokChoy
Feb 21, 2006 09:23 PM
Vtecivic99
Sep 20, 2002 05:08 PM
