99 Accord Brake Rotor bolt size?
the rotor is not bolted on. it's held in place with two screws. remove the caliper & mounting bracket to remove the rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">the rotor is not bolted on. it's held in place with two screws. remove the caliper & mounting bracket to remove the rotor.
I'll take the wheel of again and have another look. BRB!
</TD></TR></TABLE>I'll take the wheel of again and have another look. BRB!
I got it...there is a lip that holds the rotor on very tightly...it looks almost like I had to remove the axle bolt to get the whole mess off....a quote I heard one time came in handy....."at first is you don't succeed, try a bigger hammer" problem solved.
TrueUntilDeath.com
Sep 6, 2004 05:22 PM
any idea what the bolt sizeis so I can take the rotor off?
the BFH is a mechanic's best friend.
