*93 CIVIC B18C CHIPET P28 ECU* Should i keep my stock gsr intake maniflod or change it?
hi i got a 93 civic with a b18c swap, im runing a chipet p28 ecu.. i have a stock gsr intake maniflod and i know my secondaries dont work..would it worth the money changing my intake manifold to skunk2 so it will get rid of secondaries??
SO CHANGE OR DONT CHANGE? THANKS ALOT FOR YOUR HELP!!!!!!!
If your not wanting to spend a lot of money, just take off your IM, and disconnect the dual stage, and remove the secondary butterlies completely from your IM. You can unbolt it and remove the whole plate, then get a new gasket, and bolt the manifold back together. I had been running it like that for a while before I wrecked my GSR, and everything ran smoothly.
wow sounds complacated .. im not vary handy when it comes to working on cars.. but all talk to shop i go to about that. thanks...
But would changine my stock intake mani. to a skunk 2 be a good up grade on a b18c? I no some one selling one brand new for $375 canadian... OR is it better to maintain my stock one? THANK U
ted
Mar 21, 2005 05:40 PM
