A\C wiring OBD specific?
if yu want to selll everything as a whole then it must go back in a 92-95. im assuming all coolant lines and harnesses. but if your piecing it out (you'll make more money this way) some parts are interchangeable, but not all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">if yu want to selll everything as a whole then it must go back in a 92-95. im assuming all coolant lines and harnesses. but if your piecing it out (you'll make more money this way) some parts are interchangeable, but not all</TD></TR></TABLE>
Yes, the entire system will be removed. Know where I can find a compatibility list? Only thing I can think of being used between both is the compressor.
Its not so much OBD specific but physically compatable with different cars, its the same basic setup but its made to fit on different brackets and what not more then anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">Its not so much OBD specific but physically compatable with different cars, its the same basic setup but its made to fit on different brackets and what not more then anything.</TD></TR></TABLE>
Got it, makes sense. So my best bet is just market it to the 92-95 crowd.
