Wierd vibration/grind noise
Old Jul 19, 2005 | 05:45 AM
Boosted_K20A3's Avatar
Default Wierd vibration/grind noise
Well here is the deal, I am hearing a slight vibration or a grind when I let off the gas and just coast. It isn't a loud noise or anything. I am not sure if it is the tranny or not. It is coming from the driver's side. This vibration happens every once in a while, so it is not everytime I drive. Like I said it only happens when I let off the gas and just coast for a lil bit. I am not sure if it is road noise, my coilover suspention, tires, etc. I think I am just scaring myself into thinking it is something bad. I am not throwing any CEL's either. I took it to Acura and they couldn't figure out what it is and said that "you should be fine" I went ahead and had the tranny flushed there and they said the fluid was nasty. So anyways, if you can help me out I would appreciate it a lot.
Old Jul 20, 2005 | 11:02 AM
in-n-outboy's Avatar
Default Re: Wierd vibration/grind noise (Boosted_K20A3)
maybe it is your coilovers oan exhaust rattle(if u have one) try that.
Old Jul 20, 2005 | 07:17 PM
REPOSSESSEDHX's Avatar
Probably your suspension. I have an ep3 and i am having the same problem. It seems that no one can find an answer on fixing the problem, so you are probably just going to have to live with the problem.
Old Jul 20, 2005 | 08:36 PM
03ephatch's Avatar
Default Re: Wierd vibration/grind noise (IVTEC-DO U)
check for loose parts/ suspension components.
DaveSi677
Nov 4, 2008 07:18 AM
hondafrk505
Aug 30, 2006 05:21 PM
aZnjCC
Aug 31, 2003 01:28 PM
azian21485
May 19, 2003 10:27 PM
94Gizzer
May 16, 2003 03:59 AM
