How the heck are you guys doing it?? I"m lost :)
Old Feb 17, 2002 | 05:47 PM
13secondcivic's Avatar
New User
Default How the heck are you guys doing it?? I"m lost :)
well, I did a search on this topic and found one thing recently.....I gotta know though, HOW are you guys using the stock clutch cable and throttle cable on a B16A1 swap into a 4th gen civic???????????????????????
I got the teg throttle cable because the Si cable wasn't even CLOSE to fitting in the mount bracket!!!!!!!!! and as for the clutch, the damn thing is so tight I have no freeplay, the pedal is almost touching the dash, and if I push the pedal to the floor, something in the clutch actually grabs and locks up everything! it's just way too tight to work properly....HOW HOW HOW!!!!!
Old Feb 17, 2002 | 06:00 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: How the heck are you guys doing it?? I"m lost :) (13secondcivic)
For the throttle cable i used a crxguru.com bracket.
Clutch cable- You need to use either an integra cable, OR get a dremel and take off about 2" of CASING from the clutch cable, which is what i did. Make sure you dont cut the clutch cable or else, well, youre screwed .
HTH
-Todd
Old Feb 17, 2002 | 06:03 PM
89civic1.8T's Avatar
I did mine alittle weird. Fist I trimed the plastic adjuster nut. Then I trimed the rubber on the catcher thing that pulls up on the arm. Next I took one of bolt out of the braket on the tanny and that made the braket go crocked and when it settles I tighten the remaining bolt. I have used this setup for over a year now.
Old Feb 17, 2002 | 06:36 PM
New User
Thanks guys....i'll just get a teg cable
Old Feb 17, 2002 | 06:38 PM
New User
p.s. LOL! that throttle cable bracket cost more than a new cable! I just picked up a teg cable for 16.00! Brand new from ACURA, took 5 minutes to install.....they want 25.00 for the bracket!!!!!! PLUS 6.00 for shipping!!!! just some heads up.
ryanevansoh
Mar 23, 2009 02:02 PM
mjfubar101
Dec 25, 2007 08:20 PM
rewerbcrx
Jan 17, 2006 09:56 AM
ironchef25
10
Jan 20, 2004 12:26 PM
Verdegsr
Nov 9, 2003 07:11 AM
