What are the 3 block sensors on the back of a B16 first gen
Old Jul 18, 2005 | 08:33 PM
stillrockin18s's Avatar
Default What are the 3 block sensors on the back of a B16 first gen
Can someone tell me the names of the 3 sensors on the back of the first gen b16 blcok near the oil filter, and wire colors if possible.
There are two 2 wire sensor and one 1 wire sensor. Where is the knock sensor located? Is that the 1 wire sensor?
Tring to locate the source of a problem on my car and I am thinking some of the wires may be crossed. Any easy ways to tell? I have no CEL light, just bogging and 3.5K-4K vtec on stock ECU
Thanks in advance, this problems driving me INSANE!
UPDATE:
Well it looks like I found a bit of a mess from the guy who put my engine in.
I have 2 green sensors (2 wire), they have a white wire with green stripe and a black wire, they are wired together and the one is in the spot of the knock sensor. The sensor in the knock sensor position doesn't have the white/green wire hooked up (which I am assuming is the feed).
Now I know the knock sensor is currently hooked up to the oil sensor (1 wire sensor beside the oil filter).
My question is what is the green sensor? I guess next step is to get a knock sensor, what all knock sensors will fit?
Make any sense? I know the dude was confused about the sensor on the back but WTF, I gave him all types of diagrams.
(not mine just so you can see what I mean)
Modified by lowriden_acura at 9:36 PM 7/19/2005
Old Jul 19, 2005 | 02:38 AM
Default Re: What are the 3 block sensors on the back of a B16 first gen (lowriden_acura)
UP I know someone knows the answer
Old Jul 19, 2005 | 04:06 AM
BUMP
Old Jul 19, 2005 | 05:34 AM
UP hoping to get answers today so I can fix my car.
Old Jul 19, 2005 | 07:55 AM
UP AGAIN
Old Jul 19, 2005 | 04:44 PM
JUST ADDED MY UPDATE TO THE B16 SAGA
Old Jul 19, 2005 | 04:47 PM
ROOROWNS's Avatar
Welcome to my world. I have crazy early vtec engagement, but not as early as yours. I get it at about 4200 rpm, i have a frist gen b16 no knock. Ill check my block for you tomorow in the Day light, I think all b series KS are the same.
Old Jul 20, 2005 | 01:54 AM
Old Jul 20, 2005 | 02:07 AM
JUN-DA6's Avatar
the 3 sensors around the oil filter on your first gen b16a are:
-oil pressure sensor - 1 wire (yellow/red?)
-fan switch sensor - 2 wires (color?) on obd 1 car is located on thermostat housing.
-knock sensor - 1 wire (color?) green plug
I hope those info helps.....good luck
Old Jul 20, 2005 | 06:05 AM
Default Re: (JUN-DA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">
Would that be the green sensor just right & above of the Oil Filter? I think this is the sensor I have 2 of. The ones just grounded. I have a green 2 wire sensor where the knock sensor should be. It has a white green wire (feed) and a black wire (ground).
The oil sensor doesn't need re-wired does it? I just use whats on my stock B18A harness? (yellow/red wire)
If I am looking through the intake manifold the knock sensor should be near the middle right under the intake manifold correct?
Old Jul 21, 2005 | 12:13 AM
JUN-DA6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowriden_acura &raquo;</TD></TR><TR><TD CLASS="quote">
The oil sensor doesn't need re-wired does it? I just use whats on my stock B18A harness? (yellow/red wire)</TD></TR></TABLE>
The 1st gen B16A should have same oil pressure sensor as the your stock B18A, so yes you can just plug it in.
If I am looking through the intake manifold the knock sensor should be near the middle right under the intake manifold correct?</TD></TR></TABLE>
That is correct, knock sensor is located on the block above the oil filter right where intake manifold meets the block.
Freeclowns
Mar 30, 2012 09:22 AM
xtremehawn
10
Dec 3, 2007 12:40 PM
juanchoenuncrx
Aug 24, 2007 04:48 AM
ZaxEG
Oct 2, 2003 07:35 PM
