difference between EG and EK rear subframe?
Old Jul 18, 2005 | 08:18 PM
DC4_MADMAN's Avatar
Default difference between EG and EK rear subframe?
Got a rear tie bar from PasswordJDM in a 3 bar package deal. I traded the tie bar as I was not going to use it, for the dizzy I needed. He tried installing on his EG and he says the bar came up well short of connecting the two points.
They dont make the tie bar for the EF chassis, and if its not fitting the EG, did they send an EK one by mistake? Are the 2 points of contact shorter on the EK than the EG?
I had him measure the bar and he says its 22 1/4", can anyone measure the distance of the 2 points on their EG and can I get someone to do the same on an EK? This would help me figure out which one I got.
Thanks.
Old Jul 19, 2005 | 06:56 AM
DC4_MADMAN's Avatar
No one has any idea?
Old Jul 19, 2005 | 07:33 AM
92HatchB16's Avatar
Default Re: difference between EG and EK rear subframe? (4door_demon)
The EG rear is way different than the EK. The EK rear does have shorter points of contact than the EG, sorry I am at work and can't measure my EG right now, but I know they are different. I would see if you can return the one you have and get the right one. Password JDM is usually really good about returns. I hope that helps you.
Old Jul 19, 2005 | 11:09 AM
B-twentyVTEC's Avatar
totally different
bigG
Suspension & Brakes
Aug 14, 2017 07:14 AM
get2knowubabe
Nov 7, 2004 06:38 PM
JDMvtecDRAGSTA
13
Jun 11, 2002 07:06 PM
