High CR, Nitrous, what plugs?
Old Jul 18, 2005 | 08:07 PM
snowseeker's Avatar
Default High CR, Nitrous, what plugs?
Spent the last hour reading threw nitrous plug threads and couldn't find what I need.
I am running 12.5:1 with a 100 wet direct port fogger CRVtec.
Now I should go 2 colder for compression but than I should go 2 colder for nitrous according to NOS and basic knowledge for CR. But going 4 plugs colder just seems like way to much.?.
Should I just start with a 11 - 12 and work my way down from there?
What do you guys suggest?
NGK only please.
Old Jul 18, 2005 | 08:24 PM
Turbocivic94's Avatar
Default Re: High CR, Nitrous, what plugs? (snowseeker)
I wouldnt run anything colder than 8.
Old Jul 19, 2005 | 08:22 AM
snowseeker's Avatar
Default Re: High CR, Nitrous, what plugs? (Turbocivic94)
Thanks, anyone else?
Old Jul 19, 2005 | 08:42 AM
aj99si's Avatar
I have a 11.5 compression 2.0 ls vtec with a 120 shot direct port and I am using the ngk bkre7 and the plugs looked real good. I have 7 runs on the plugs. With your setup I would start with a 8 but you will probably end up using the 7. On a 100 shot it says stock to 1 plug colder. With your compression the 7 is a good plug all motor. So I would say start with the 8 and go from there.
Old Jul 19, 2005 | 09:02 AM
snowseeker's Avatar
Default Re: High CR, Nitrous, what plugs? (aj99si)
NOS site says 1 to 2 steps colder with 105 oct. I'll try some 8s though. 120 on 11.5:1, hows that feel?
Old Jul 19, 2005 | 01:04 PM
RI_TM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si &raquo;</TD></TR><TR><TD CLASS="quote">I have a 11.5 compression 2.0 ls vtec with a 120 shot direct port and I am using the ngk bkre7 and the plugs looked real good. I have 7 runs on the plugs. With your setup I would start with a 8 but you will probably end up using the 7. On a 100 shot it says stock to 1 plug colder. With your compression the 7 is a good plug all motor. So I would say start with the 8 and go from there.</TD></TR></TABLE>
That's a similar setup to what i have, except i have a milled head putting it somewhere close to 12.0 compresson(I'll say 11.8-11.9) 81.5 bore. Had a single fogger 70 shot...trying it with a 100-120 direct port soon!....using bkre 8.
Curious...how did it perform...any #'s?
Old Jul 19, 2005 | 04:57 PM
snowseeker's Avatar
Default Re: High CR, Nitrous, what plugs? (RI_TM)
Motors not in the car yet. lol But getting close.
Thanks again! H-T
Old Jul 19, 2005 | 07:29 PM
Phase Change Racing's Avatar
I would not expect you to experience any problems running 4 ranges colder plugs on your engine but 2 colder will probably do ya just fine. Is this a race-only vehicle, street/strip, or street only vehicle? Spark plugs really are not that crucial of component and plug-fouling is a pretty rare occurance with you 4-valve per cylinder EFI guys. Start out cold and work your way up if needed, running a "colder than needed" plug isn't going to hurt you as long as you are not having problems fouling them out. Worst case senario is you foul a few plugs and have to spend $6 on new ones (assuming you know not to buy bling bling plugs at this point).
Old Jul 19, 2005 | 08:07 PM
snowseeker's Avatar
Default Re: High CR, Nitrous, what plugs? (Phase Change Racing)
Plan on around 400 miles a year on the street. Mostly all town driving and a couple races on the weekends.
Of course it will be at the track 3 - 4 times a month.
Old Jul 19, 2005 | 08:19 PM
cubish's Avatar
i ran 7's on my car forever. and i had around 13.5 to 1 compression and more than double of what you are trying to spray. i ran the car on c16 gas
Old Jul 19, 2005 | 08:31 PM
snowseeker's Avatar
Default Re: High CR, Nitrous, what plugs? (cubish)
Ima start with the 8's and see if those don't burn up. 7's with 13.5:1 with the junk is just amazing! If you don't mind could you PM me about what system you were running and what you were shooting at it?
I was going to either run the turbo blue pump gas (110) or C12.
Old Jul 20, 2005 | 09:04 AM
aj99si's Avatar
It did ok I had serious traction problems though. It ran a 11.63 at 118.75 with a 1.78 60ft. I was spinning all the way through first and second on M and H 24.5x8.5x13. It was the first night I was out there with the new setup. My ebrake did not hold so I could not do a very good burnout. I ran it all motor the first 2 runs to break it in and it ran a 12.5 so there is room for improvement when I get traction with the nitrous. I just bought a nitrous controller so I think the setup is good for a 11.20.
Old Jul 20, 2005 | 11:26 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si &raquo;</TD></TR><TR><TD CLASS="quote"> It did ok I had serious traction problems though. It ran a 11.63 at 118.75 with a 1.78 60ft. I was spinning all the way through first and second on M and H 24.5x8.5x13. It was the first night I was out there with the new setup. My ebrake did not hold so I could not do a very good burnout. I ran it all motor the first 2 runs to break it in and it ran a 12.5 so there is room for improvement when I get traction with the nitrous. I just bought a nitrous controller so I think the setup is good for a 11.20.</TD></TR></TABLE>
That on stock sleeves? 1.78 ain't bad. Best I could get out of my 22x8x13 M&H with my old motor was a 2.0 But I didn't have an ebrake at all so that didn't help. Have a couple linelocks for this year.
What PSI did you have in the slicks and stock axles?
Old Jul 20, 2005 | 05:21 PM
aj99si's Avatar
The block is sleeved and I had 10 psi in the tires. I am running stock axles. They were used last year too. They have about 50 launches on them. I like to spin a little off the line it saves the axles. I had the block sleeved because I am going to be upping the shot to a 200 with the progressive nitrous controller. I will probably start with about a 80 shot out of the hole and the controller will bring the nitrous on gradually from the 80 to 200 in whatever time period I want.
gtmcoupe
Mar 22, 2010 12:46 PM
K20ISR
Mar 30, 2009 07:27 AM
shhh151
Dec 15, 2006 03:51 PM
Slic00Si
May 16, 2004 09:24 PM
