Which Throttle cable bracket to use???
I have a 92 EG civic and was wonder which Throttle cable bracket to use on my JDM b16a? I made one out of a peice of scrap metal i had but its way to ugly for me. I did a search but found nothing?
You may be able to modify the one that came with the engine. That's what I did on the CRX. I flipped it upside down, and re bent it to face the other way.
anyways, just an idea.
If i understood correctly you can use the bracket extension from a GSR and bolt right to your TB, you may have to shorten extended wire section of cable though.
Crank
Nov 7, 2008 02:30 PM
GSR-TRBO-DA
Jan 13, 2008 04:30 PM
b16nonoy
Feb 2, 2007 09:18 PM
spart
Feb 17, 2002 10:18 PM
