Just Finished my Fuel System... Take a look (Pics inside)
Well I spent yesterday on my day off putting my fuel System in my car. It took me a bit to get everything in Black like I wanted but finally got all the components. Little Rundown...
10 Gal Alum. Cell
Dual -8 Lines to Distribution Block
-12 line to 40micron Filter and Weldon Pump
-10 all the way up to my 10 Micron Filter
GE Fuel Rail
1600cc Precision Injectors
Aeromotive FPR
-8 all the way back into the Cell.
I still have to builid a box around the cell and plum in the Aeromotive FPR. Other than that, I am pretty happy with the install. Everything was Pop Rivited to hold the lines up.
Thanks for Looking
Corey
Modified by 95c1v1cs1 at 10:22 AM 7/19/2005
10 Gal Alum. Cell
GE Fuel Rail
Aeromotive FPR
Thanks for Looking
Corey
Who is Mr Robot?
looks good. my fuel system im installing is the same except im running an aeromotive pump and im sumping the stock tank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">looks almost like a factory install</TD></TR></TABLE>
Thanks Alot, I appreciate that.
Modified by 95c1v1cs1 at 8:49 AM 7/19/2005
hot damnn! that looks awsomeee
but i dont know about the filter there....i know its right behind the subframe, but what *if* something happens to kick up and knock off the filter, the motor will lose all fuel. I would mount it the other way. unless this is DRAG only car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">um, home depot sells those as well as rivets and pop-rivet guns
Low blow! so what about the loop things?!!?!
</TD></TR></TABLE>Low blow! so what about the loop things?!!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">*nut check*
home depot sells those too.. look in the elctrical or plumbing section... i remember seeing them
hahah Great .
Homedepot rat.
</TD></TR></TABLE>hahah Great .
Homedepot rat.
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic »</TD></TR><TR><TD CLASS="quote">
hahah Great .
Homedepot rat.</TD></TR></TABLE>
lol. its just a cheaper alternative
im running the exact same fuel setup in my car, now i know how to mount it
hahah Great .
Homedepot rat.</TD></TR></TABLE>lol. its just a cheaper alternative
Nice fuel setup man... I'm going to start on mine this weekend. Im going to run the stock fuel return sytem and just install a new feed line. Im using the aeromotive a1000.. Is this going to be your drag car?
Thanks for all the Replies.
This is a Drag Car only. I have been saving parts for some time and things are finally starting to come together. All the Fuel Line Holders I got from Jegs and Pop Rivets and guns are used for many things. Yes Home Depot Does Sell them
It was a good alternative to people using Self Tapping Screws.
Pure Death. The Fuel System Including Rail, Injectors, Pump, Filters, Lines, Fittings, Cell, Distribution Block, FPR, etc prolly costs around 1500-2000. I do sell Weldon Pumps and that particular one (1200hp) runs about $650.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 »</TD></TR><TR><TD CLASS="quote">
For some reason, this pic gives me a boner. I think it's those sweet aluminum welds...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo »</TD></TR><TR><TD CLASS="quote">Corey that looks great. Is this your coupe?</TD></TR></TABLE>
This is my Hatch. I decided against doing the Coupe.
That is ridiculously clean looking. I hope those -12 lines will be enough though haha
Is that fuel cell DOT approved? If so where did you get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">That is ridiculously clean looking. I hope those -12 lines will be enough though haha
Is that fuel cell DOT approved? If so where did you get it?</TD></TR></TABLE>
Fuel Cell came from Jegs. It is DOT approved.
Corey
Is that fuel cell DOT approved? If so where did you get it?</TD></TR></TABLE>Fuel Cell came from Jegs. It is DOT approved.
Corey
