integra with 16
Old Jul 18, 2005 | 06:15 PM
astroxtc's Avatar
Default integra with 16
im in the market for some 16's and i was just wonderin woudl the 16 make the car slower. or should i just stick with 15s
Old Jul 18, 2005 | 06:28 PM
EMJAY's Avatar
y would it make your car slower? unless its heavier then it might a eighth of a second...
common sense bro
Old Jul 18, 2005 | 06:37 PM
astroxtc's Avatar
the rotation mass?
Old Jul 18, 2005 | 06:38 PM
numbnuts22715's Avatar
itll make the speedo off if you dont get smaller tires, but itsnot going to make your car slower unless theyre heavier than your old ones.
EDIT: Fixed.
Modified by numbnuts22715 at 10:09 PM 7/18/2005
Old Jul 18, 2005 | 06:54 PM
BuyImports2's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">itll make the speedo off, but itsnot going to make your car slower unless theyre heavy...</TD></TR></TABLE>
not true, and partly not true.
16's will not make your speedo off. buying the incorrect tire size will make your speedo off.
heavier wheels will make the car slower. larger wheels WILL make your car slower, unless they are lighter than smaller wheels, which they almost never are. if you have two wheels of the exact same weight, one 15", one 18", the 18's will be slower becuase the mass is farther from the center.
is far as what whether to get 15's or 16's, it all depends. 16's will not have that much of a weight difference from 15's. i chose to go 15 because where i live, the road are horrendous and i didn't want to bend a rim. bigger wheels look fancier, however
Old Jul 19, 2005 | 11:18 AM
fuzzyclam03's Avatar
Default Re: (BuyImports2)
are 17"s better for highway cruising in comparision to 15"s? i know 17"s suck in the city... heavier mass that is futher from the center = higher amount of momentum (inertia) built up which will take more stopping power ... but how are they on the highway? better fuel milage?
Old Jul 19, 2005 | 11:43 AM
I dont see why theyd be better. Theyre not going to be as smooth, not as nice of a ride.
Old Jul 19, 2005 | 12:48 PM
XSIWANNAB's Avatar
go with 20's ive seen it done and they add 10 hp they grap more gravel,trust me......
lisa kubo said so
Old Jul 19, 2005 | 02:13 PM
Default Re: (XSIWANNAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIWANNAB &raquo;</TD></TR><TR><TD CLASS="quote">go with 20's ive seen it done and they add 10 hp they grap more gravel,trust me......
lisa kubo said so </TD></TR></TABLE>
thanks for the completely worthless post.
I can't imagine that 17's will give you any noticeable gas milage gain. if you want better gas milage, just add some psi to your 15's.
Old Jul 19, 2005 | 03:56 PM
PandaBear's Avatar
16 is "heavier" than 15 even if they weight the same due to inertia difference, the mass is on the outer edge so it takes more energy to start and more energy to stop.
On the other hand, lower profile tire should have less rolling resistance, but not going to make up the same amount as the higher inertia.
15 for performance and handling
16 for good compromise
17 for show
Baggy Spandex
Jul 26, 2014 06:27 PM
lambertincorp
Sep 17, 2007 02:55 PM
civic2sick
Aug 15, 2006 11:06 AM
ezekel
May 1, 2006 07:13 PM
icbmatt
Apr 22, 2006 08:05 AM
