charging system problem
Old Jul 18, 2005 | 06:01 PM
dat_flip's Avatar
Default charging system problem
I am having a little problem with my charging system. I already changed the alternator (had a few laying around in my garage so its not a new one) and installed a new optima yellow top battery. My problem is that when i first start the car, it doesn't matter if it is for the first time of the day or weather it is already warmed up it will show a 14+volt charge on my voltmeter. But once i start driving it it bounces between 12.5-14.2 volts and at night my lights go dim and after about 3500rpm my lights get brighter. I wanted to know if this is normal or if I actually have something wrong with my charging system. If its any help it is an obd2 b18b engine.
Old Jul 19, 2005 | 10:33 AM
dat_flip's Avatar
Default Re: charging system problem (dat_flip)
anyone?
Old Jul 19, 2005 | 11:38 AM
senpai's Avatar
if you turn on accessories and the voltage drops way too low, then it's the alternator
Old Jul 19, 2005 | 12:45 PM
EE_Chris's Avatar
You have underdrive pulleys installed?
Old Jul 19, 2005 | 04:02 PM
dat_flip's Avatar
Default Re: charging system problem (EE_Chris)
no underdrive pulleys
Old Jul 20, 2005 | 09:31 AM
vtecb20coupe's Avatar
B A N N E D
what year is the car? sound similar to the issue i have with my 98 coupe. cel showed up before with a electrical load detector issue. alternator was overcharging, etc. haven't completely fixed the issue yet.
Old Jul 20, 2005 | 10:26 AM
dat_flip's Avatar
Default Re: charging system problem (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">what year is the car? sound similar to the issue i have with my 98 coupe. cel showed up before with a electrical load detector issue. alternator was overcharging, etc. haven't completely fixed the issue yet.</TD></TR></TABLE>
Mine is a 97 hatch. I am not getting no cels. I am thinking its the ELD also so im gonna change that out when I get the part in. I will let you know how it works out
Old Jul 20, 2005 | 03:16 PM
senpai's Avatar
how are you overcharging with only 14v?
Old Jul 21, 2005 | 09:14 AM
DelSolDon's Avatar
Default Re: charging system problem (senpai)
check, or just replace the cable running from the alternator to the fuse box.
Old Jul 21, 2005 | 11:36 AM
dat_flip's Avatar
Default Re: charging system problem (DelSolDon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">check, or just replace the cable running from the alternator to the fuse box.</TD></TR></TABLE>
ohm'd it out......... its good
Old Sep 1, 2005 | 11:40 PM
dat_flip's Avatar
still doing it
wagstation
Honda CR-V & Element
Sep 18, 2017 03:18 PM
Mishka24
Honda Fit
Jun 24, 2010 11:15 AM
EJ8chu
Sep 23, 2008 05:28 PM
