Need help my girlfriends friend put dirty oil in her gastank!!!!
Old Jul 18, 2005 | 03:35 PM
Steezn4NOReason's Avatar
Default Need help my girlfriends friend put dirty oil in her gastank!!!!
my friend put almost a gallon of dirty oil in her gas tank thinking it was gas in her tank and drove it about a mile and than it just stopped. i know hondas pretty well so i think i can fix it i have the gas tank pulled and thats bout it. what do i need to look at to fix this any advise would help. oh if someone can help me ill send em some $ in the mail. cuz its saving her $. thanks
Old Jul 18, 2005 | 03:39 PM
Street Ghost's Avatar
Default Re: Need help my girlfriends friend put dirty oil in her gastank!!!! (Steezn4NOReason)
the fuel filter could be clogged, as well as the injectors. basically i would check all the fuel related parts.. fuel pump, fuel filter, fuel lines, fuel rail, fuel injectors. oil is pretty thick compared to fuel.. so the reason why the car stopped running could mean things are clogged.
Old Jul 18, 2005 | 03:40 PM
civiccoupe94's Avatar
just hope the fuel filter got clogged with oil and not getting it to the engine. try replacing the fuel filter, its only 15 bucks
Old Jul 18, 2005 | 03:45 PM
Luserkid's Avatar
Default Re: (civiccoupe94)
That friend isnt a friend and needs to be put down.
If your lucky and it didnt get past the filter then your good. If it went past your basically fucked.
Edit: Actually if it got to the fuel filter in the engine bay your fucked because its in the lines. and youll never beable to get those out. So hope its only stuck in the little filter in the fuel pump.
Old Jul 18, 2005 | 03:48 PM
Reid's Avatar
Global Moderator
Clean the tank and all of the lines to and from the gas tank thoroughly with engine degreaser.
Change the filter on the fuel pump along with the fuel filter.
Send the injectors out to be cleaned.
Once all of those parts are cleaned/changed and reinstalled, I would run a can of Seafoam through the engine to aid with cleaning out the oil in the combustion chamber.
Old Jul 18, 2005 | 03:50 PM
Reid's Avatar
Global Moderator
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Edit: Actually if it got to the fuel filter in the engine bay your fucked because its in the lines.</TD></TR></TABLE>
It obviously reached at least the fuel filter if engine performance was affected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">and youll never beable to get those out. So hope its only stuck in the little filter in the fuel pump. </TD></TR></TABLE>
I've removed fuel lines from Hondas, cleaned, and reinstalled them.
Old Jul 18, 2005 | 04:03 PM
what are the chances that the oil got past the fuel filter in the engine bay. because the motor did shut off... usually wouldnt the engine shut off if the filter got clogged. i guess the car kinda sputtered out "kinda like running out of gas".... so i dont think it got to the motor. how hard are the fuel lines to pull out???
Old Jul 18, 2005 | 04:06 PM
Luserkid's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
I've removed fuel lines from Hondas, cleaned, and reinstalled them. </TD></TR></TABLE>
What did you use when you cleaned the lines. Just sprayed degreaser in it and let it sit or something?
Old Jul 18, 2005 | 04:23 PM
mingbling96's Avatar
i think you're okae. just change the fuel filter and clean out your tank. The reason being is fuel is a good solvent for oil and should break it up over time if it didnt damage the fuel pump.
Old Jul 18, 2005 | 04:25 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">What did you use when you cleaned the lines. Just sprayed degreaser in it and let it sit or something? </TD></TR></TABLE>
Yes.
What made you say that they're impossible to remove?
Old Jul 18, 2005 | 09:04 PM
Default Re: (Reid)
the fuel filter is being a pain in the *** to get off, i got the top line off. the side line is a bitch. any advise on how to get that off? its tight as ****.....
Old Jul 18, 2005 | 09:08 PM
RC211V's Avatar
Default Re: (Steezn4NOReason)
man i am sorry but, Ahahaha
Old Jul 19, 2005 | 10:43 AM
GoGators's Avatar
You are using two wrenches, correct? Sometimes I read someone's trying to do it with one, yikes. Flare wrenches are nice if you got em. Eat your vegetables and torque that ****.
Old Jul 19, 2005 | 12:45 PM
Luserkid's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">What made you say that they're impossible to remove? </TD></TR></TABLE>
I figured since oil was all grimmy and **** you couldnt be 100% sure to get it all out also being hard lines you only know one end for another. But its good to know that its easy to clean.
phenomB16
Jul 5, 2013 08:18 AM
crappyshifting
Apr 5, 2011 07:44 AM
Novz
Jan 7, 2011 11:47 AM
dirrtybirdy
Dec 4, 2007 06:09 PM
NCTUAN03
Apr 20, 2005 07:37 AM
