swapped 98engine in to 99
Old Jul 18, 2005 | 03:33 PM
99hcguy's Avatar
Default swapped 98engine in to 99
i swapped a 98 d16y8 into my 99 ex it was missing a vacume line. i spliced the line into another one. it has been running fine till recently and my check engine light is on now i got it checked it said it was the idle speed control. my cruise does not work. the idle is real high when i first start it in the morning till it get warmed up then its fine. When i push on the gas it jerks and when i let off the gas it jerks but when the gas is on it ok but sometimes it jerks real bad when i'm goping slow but in a low gear. i need help so if anyone can tell me whats up it would be appreciated
Old Jul 18, 2005 | 03:56 PM
Civicse's Avatar
Default Re: swapped 98engine in to 99 (99hcguy)
that happened to me once and it turned out to be a sliced wire on the o2 sensor, i don't know if thats ur problem but mind as well give it a check
Old Jul 18, 2005 | 04:46 PM
hookedonvtec's Avatar
Default Re: swapped 98engine in to 99 (Civicse)
kinda sucks cause its illegal to put an older motor in a newer car. happen to a friend and say hello to state ref and say good bye to ur motor being in that car
Old Jul 18, 2005 | 04:47 PM
oh and to help u out, mine did that also, turned out it was the dizzy. is it throwing any codes? theres a idle control valve on the intake mani and if u clean that out it helps a lot too.
Old Jul 18, 2005 | 04:52 PM
komat's Avatar
Default Re: swapped 98engine in to 99 (hookedonvtec)
he lives in pa so he doesnt have to worry about that
Old Jul 18, 2005 | 05:06 PM
young noob's Avatar
Default Re: swapped 98engine in to 99 (komat)
ok, not to interupt this thread, but what is that rule for the older motor into newer car, or is that only for cali residents??????
thanks
Old Jul 18, 2005 | 07:09 PM
99hcguy's Avatar
i'll have to check those wires the code came back p1508 idle speed control is that the same as the iacv because i changed it from the one off my original intake manifold i cleaned the screen and everything and it did the same thing so i don;t think its that
maxogsr
16
Aug 12, 2011 02:00 PM
xmsdx
10
Apr 15, 2009 01:02 PM
Projcivic99
Apr 14, 2009 07:03 PM
theshamgod
Mar 25, 2009 08:18 AM
