Weird electrical problem on 93 Civic...
**** has me stumped..this is on my friend's 93 hatch...he changed his left front turn signal bulb one day and now all of a sudden ALL the dash cluster gauges(speedo, tach, etc) and dash lights(turn signals, oil light, etc.) do not work or some on when the car is turned on. the only dash lights that come on are the SRS and Batt. lights when you first turn the ignition, but they go out as normal once the car is on.
also with the car on, the actual turnsignals do not work either when the switch is flicked and they don't flash on the dash either...BUT when the hazard button is pushed the hazzards DO work and DO flash on the dash cluster as well...WTF!?!?
we checked all of the fuses and relays, but everything checks out fine...I'm confused as hell
any ideas where to go from here??
I had this problem the other day.
Check the fuse that is labeled as the 'backup fuse' or 'backup light'. Replace that fuse, all your dash lights/turn signals should work from there.
Oh, the fuse is a 10amp fuse as well.
Now, I'm not 100% what the fuse is called.. But it's something like 'backup light' or 'reverse light' or something like that.
VTECtravler
13
Oct 4, 2006 07:51 AM
CRXsiproject
Oct 19, 2005 12:15 AM
