Getting behind the firewall
Old Jul 18, 2005 | 02:58 PM
Liquidgsr's Avatar
Default Getting behind the firewall
Anyone know how to remove the piece that covers up the gap behind the firewall. I want to run some wires for my amp, foglights, and headunit behind there so the engine has a cleaner look, but can't seem to figure out how to take it off without breaking it.
Old Jul 18, 2005 | 03:05 PM
VtecSyndrome's Avatar
Default Re: Getting behind the firewall (Liquidgsr)
Do you mean the windshield cowl under the wipers??? if you want to run wires, you should just run them through the firewall where honda has already run wires. On the DAs you can run it through on either side w/o much trouble and w/o having to take anything off. I ran my wires this way and you can't even see them, that's also how most stereo places do it.
Old Jul 18, 2005 | 03:16 PM
Liquidgsr's Avatar
Default Re: Getting behind the firewall (VtecSyndrome)
ok so run it behind the dash? Is there a rubber gormet on the passanger side like the driver side where i can run these wires?
Old Jul 18, 2005 | 03:35 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
94-01 Integras have a large grommet down below the fuel filter, slightly lower than the battery tray. Just cut a slit and push the wires through, and the rubber will stay together tight enough around the wires to not let any water or anything inside the car.
Old Jul 18, 2005 | 03:53 PM
Liquidgsr's Avatar
Default Re: Getting behind the firewall (PatrickGSR94)
thanks patrick
Old Jul 18, 2005 | 07:19 PM
Liquidgsr's Avatar
any idea exactly where that pops out on the other side. I was looking up under the dash but didn't see where it might be on the inside. I guess i will try to stick some hard wire through tie it to the 3 wires i want to put through and do it that way. Thinking i should run my alarm wire up through there also to make shorter and harder to to for thieves.
Old Jul 18, 2005 | 08:44 PM
IN VTEC's Avatar
Right behind the AC evaporator box. If you push the wires through, they'll push their way down....and even if they don't, you will be able to reach up high enough to get them with your fingers.
Old Jul 19, 2005 | 05:04 AM
Liquidgsr's Avatar
Default Re: Getting behind the firewall (IN VTEC)
well thing is im pushing them from inside the car into the engine bay to wire up to the battery. So im actually pushing in the opposite direction...but i will try a hard wire to tie the other wires to so i can pull them through.
AEK9
Jun 7, 2011 01:20 PM
mikess06
Acura TL, RL & ZDX
Mar 24, 2008 08:12 AM
russellfx
Jan 24, 2005 07:09 PM
Z6REX-SI
Jan 5, 2004 09:22 AM
Mr. Softee
Jul 4, 2002 04:28 PM
