ECU for a Prelude BB1 H22A Engine (190hp) with Auto Transission!?!
Old Jul 18, 2005 | 02:31 PM
FLAMEDII's Avatar
Default ECU for a Prelude BB1 H22A Engine (190hp) with Auto Transission!?!
I need an ECU from/for a Prelude BB1 H22A Engine (190hp) with AT Transmission!!!!
Old Jul 18, 2005 | 02:37 PM
Lewdin' Incognito's Avatar
Default Re: ECU for a Prelude BB1 H22A Engine (190hp) with Auto Transission!?! (FLAMEDII)
ebay and check the FOR SALE section
Old Jul 18, 2005 | 02:59 PM
FLAMEDII's Avatar
Default Re: ECU for a Prelude BB1 H22A Engine (Lewdin' Incognito)
Yes, I already checked ebay, but I don`t now what ECU type it is, P13-900 , P13-N5O or what type???
Which P13 Ecu do I need for the Prelude BB1 H22a with 190hp and AT Transmission???
Old Jul 19, 2005 | 01:49 AM
FLAMEDII's Avatar
Default Re: ECU for a Prelude BB1 H22A Engine (FLAMEDII)
Nobody an Idea
Old Jul 19, 2005 | 04:11 AM
pretty sure p13 or p28 would work, I believe the p28 cuts out the oxygen sensor(??) I don't know, but the p13 is the one I went with.
EDIT: Oh sorry I misread your post, I'm not exactly sure which p13 you need. You should be able to search and find which was in the 93-96 prelude (h22a)
Modified by Lewdin' Incognito at 5:57 AM 7/19/2005
Old Jul 19, 2005 | 07:58 AM
FLAMEDII's Avatar
You should know that I come from Germany and it is very hard to find in Germany a BB1 P13 ECU with AT Trannsmission. I am the one in Germany who have a BB H22A Prelude with AT Transmission. In Germany are a lot of BB1 with M/T Transmission, but no one with Automatic Transmission. I swapped a BB6 (OBD2) H22A5 Vtec Engine with 185hp into my US Prelude BB2 AT Transmission (with 160hp, Non-Vtec). I bought a OBD1 BB4 P13 ECU, which is for the 200hp engine to make that Vtec works, and now it works, but now the car goes not faster than 100mph. With my old P14 BB2 Non-Vtec ECU the Vtec doesn`t works, but the car is faster as with the P13 BB4 ECU (with VTEC). I think the problem is that the BB4 200hp H22A ECU is not the same like the BB1 185/190hp ECU. Could be that the BB4 ECU has longer injection timing as the BB1 ECU, because of the different horsepower.
Old Jul 19, 2005 | 08:32 AM
94Vtecluder's Avatar
BB1 = Gen 4 Prelude
Gen 4 Preludes only came in manual not automatic AFAIK
Old Jul 19, 2005 | 08:45 AM
Eddiebx's Avatar
you need to look for a JDM p13 automatic ecu, I believe it would be called a xxxxxxx - p13 - x5x
taht 5 is the key, for example, ilke A51, or N51. as long as its a 5, it means its an automatic
Old Jul 19, 2005 | 09:06 AM
A Blue Lude's Avatar
Default Re: ECU for a Prelude BB1 H22A Engine (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">BB1 = Gen 4 Prelude
Gen 4 Preludes only came in manual not automatic AFAIK</TD></TR></TABLE>
Only in the US...
Old Jul 19, 2005 | 03:54 PM
FLAMEDII's Avatar
Default Re: ECU for a Prelude BB1 H22A Engine (Featherfire)
Does the H22A5 Vtec Engine works with a JDM p28 ECU???
Modified by FLAMEDII at 7:04 PM 7/19/2005
Old Jul 20, 2005 | 03:14 AM
FLAMEDII's Avatar
Come on guys, no idea!
Modified by FLAMEDII at 6:40 AM 7/20/2005
Old Jul 20, 2005 | 06:59 AM
v4lu3s's Avatar
RTFM
Default Re: (Eddiebx)
your answer was already given to you in this post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">you need to look for a JDM p13 automatic ecu, I believe it would be called a xxxxxxx - p13 - x5x
taht 5 is the key, for example, ilke A51, or N51. as long as its a 5, it means its an automatic</TD></TR></TABLE>
the p28 will run the engine but everytime i see a p28 with an auto engine you get a constant transmission control modeul light, and have to manually shift.
the ecu that eddiebx described above sends the proper signals to teh TCM and will allow the car and tranny to work right.
H2B-T_teg
Apr 8, 2011 08:30 PM
GianniPotenza
Jan 20, 2010 12:37 PM
slam_d
May 16, 2007 07:44 PM
Stealth_Ek9
Jan 23, 2007 05:04 PM
S2K Luver
Mid-Atlantic (Sales)
Dec 11, 2006 06:27 PM
