Which Autozone blanks should I buy?
Old Jul 18, 2005 | 01:22 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Which Autozone blanks should I buy?
I'm looking at Autozone's website, and there are 2 types of rotors available for my car (1997 Honda Civic EX coupe, non-ABS):
BRAKE ROTOR - FRONT for a
1997 HONDA CIVIC
EX MODEL (Change)
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
DURALAST
ROTOR ONLY 3295 2 YR $21.99
*** RECOMMEND INSPECTING THE BEARINGS AND SEALS DURING
MAINTENANCE AND REPLACEMENT ***
VALUCRAFT
ROTOR ONLY 3295B 3 MO $13.99
BRAKE_ROTOR_NOTE SEE NOTE
**SERVICES 1 WHEEL ONLY; O.E. MANUFACTURER RECOMMENDS
REPLACING IN PAIRS.
Which one should I buy?
Also, I'm looking at doing a couple AutoX's this season. What brake fluid do you recommend?
Old Jul 18, 2005 | 01:24 PM
EK k kay's Avatar
Default Re: Which Autozone blanks should I buy? (boostincoupe)
I'd pick the duralast 2 yr warranty ones.
Deemeetree's Avatar
Electrician
Cheaper one. It's used for a daily driving, slow Civic.
Old Jul 18, 2005 | 01:27 PM
Default Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Cheaper one. It's used for a daily driving, slow Civic. </TD></TR></TABLE>
That's what she be!
BTW they sell brake pads for $10!!!!!
Old Jul 18, 2005 | 01:32 PM
Sijray21's Avatar
you'll be fine with the cheaper one
for fluid, ATE blue or MOTUL is pretty good
Old Jul 18, 2005 | 01:53 PM
Lee_Delso's Avatar
Add the extra money and get some brembo blanks, you'll be happier in the end.
Cheap rotors=cheap materials
Right now I got brembo blanks and hawks cereamics for daily driving and I love it.
Old Jul 18, 2005 | 02:17 PM
Deemeetree's Avatar
Electrician
I always got the cheaper replacement discs. No problems whatsoever.
Old Jul 18, 2005 | 02:50 PM
Lee_Delso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">I always got the cheaper replacement discs. No problems whatsoever. </TD></TR></TABLE>
because you are a 04' moderator! and we're not!
Old Jul 18, 2005 | 02:54 PM
Deemeetree's Avatar
Electrician
Default Re: (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso &raquo;</TD></TR><TR><TD CLASS="quote">because you are a 04' moderator! and we're not! </TD></TR></TABLE>
Ya' caught me! They give me the special ones at the cheap one's price because I'm l33t.
Depends on what type of driving you're doing, on a daily basis. If it's normal street driving, any replacement will do.
Old Jul 18, 2005 | 03:12 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">you'll be fine with the cheaper one
for fluid, ATE blue or MOTUL is pretty good</TD></TR></TABLE>
Uhhhhhhhhhhhh............ No. That stuff has a tendancy to collect water much faster than normal brake fluid. The best thing to go with if it's for daily driving is honda brake fluid.
I've upgraded my brakes almost 10 months ago, and I had to put in new brake fluid, that **** is STILL clean and works great, and there is some track days in it as well. Why spend a bunch of money on brake fluid that won't do **** for you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what type of driving you're doing, on a daily basis. If it's normal street driving, any replacement will do. </TD></TR></TABLE>
Exactly, now if you go to the track a lot, then and upgraded replacement will do....like brembo blanks. I have some and absolutely love them.
Old Jul 18, 2005 | 03:49 PM
Sijray21's Avatar
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
i've used ATE super blue for a while now, as well as the track. Has been working great, no water collection, for about 7/8 months now
edit: after doing some research Motul does tend to soak up a little more brake fluid, but ATE blue does not. i've never used Motul in my car, but i have friends that do (but only on the track). I'll stand by ATE Super Blue though.
and thinking about the original post, you really don't need anything other than stock DOT fluid unless you'll be going to the track...in an auto-x you shouldn't need higher DOT fluid, it simply won't get that hot.
Old Jul 18, 2005 | 03:56 PM
Reid's Avatar
Global Moderator
Default Re: Which Autozone blanks should I buy? (Lee_Delso)
Whoa, lots of misinformation in this thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso &raquo;</TD></TR><TR><TD CLASS="quote">Add the extra money and get some brembo blanks, you'll be happier in the end.
Right now I got brembo blanks and hawks cereamics for daily driving and I love it. </TD></TR></TABLE>
Rotors = wear item
There is no point in spending more money for rotors, than you have to. Get the cheapest rotors available.
On the track, the cheap stuff will last just as long as more expensive, "better" rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Uhhhhhhhhhhhh............ No. That stuff has a tendancy to collect water much faster than normal brake fluid. The best thing to go with if it's for daily driving is honda brake fluid.</TD></TR></TABLE>
I use Motul RBF 600 and ATE Super Blue in various street cars. The brakes are not bled nearly as much as on my track car, and the street cars' brakes are holding up fine.
Motul RBF 600 does have a tendency to collect water faster than normal brake fluid, but it's not a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">I've upgraded my brakes almost 10 months ago, and I had to put in new brake fluid, that **** is STILL clean and works great, and there is some track days in it as well. Why spend a bunch of money on brake fluid that won't do **** for you?</TD></TR></TABLE>
If you did not boil the Honda brake fluid out on the track, then you're not braking nearly hard enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, now if you go to the track a lot, then and upgraded replacement will do....like brembo blanks. I have some and absolutely love them. </TD></TR></TABLE>
See my comment above WRT to brake rotors and the "more expensive = better" school of thought.
ninjavet
Honda Civic (2006 - 2015)
Sep 16, 2016 03:32 AM
Tudm91
Oct 22, 2012 11:08 AM
oskar_0709
Oct 14, 2010 06:12 AM
boostincoupe
23
Jul 20, 2005 08:01 PM
