FS: vtec solenoid
Old Jul 18, 2005 | 11:48 AM
RCautoworks's Avatar
Default FS: vtec solenoid
FS: B series vtec solenoid, only has 1 sensor which is the vtec sensor, item in pic is different. Just showing you what a vtec solenoid is
Old Jul 27, 2005 | 04:08 PM
dr_latino999's Avatar
Default Re: FS: vtec solenoid (90blackcrx)
What about the oil pressure switch/sensor doohicky, is that another item all together?
Old Jul 27, 2005 | 05:18 PM
Default Re: FS: vtec solenoid (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">What about the oil pressure switch/sensor doohicky, is that another item all together?</TD></TR></TABLE>
You could drill and tap for it I suppose. Some ecu's do not look for that sensor though. The sensor was never on there to began with from the factory, there is a casting hole, where you would drill, then tap for the sensor
Old Jul 28, 2005 | 06:09 PM
To the top
Old Jul 29, 2005 | 02:34 PM
Anyone need one ?
Old Jul 30, 2005 | 10:30 AM
Go White Sox
Old Aug 1, 2005 | 10:59 AM
25 bucks takes it
LOVEthatDC2
Aug 25, 2009 09:29 AM
PinkMaggit
Mar 12, 2007 05:43 AM
