car lists to the left!
Old Jul 18, 2005 | 09:21 AM
mrdeadman's Avatar
They let me pick
Default car lists to the left!
this sucks, if i let the steering wheel go it lists to the left pretty bad, this only happens when im doing 65+ and not under braking when im doing about 45. what could be the problem? thanks. peace.
Old Jul 18, 2005 | 09:24 AM
numbnuts22715's Avatar
get an alignment?
or your tires could not be properly inflated.
Old Jul 18, 2005 | 09:26 AM
mrdeadman's Avatar
They let me pick
Default Re: (numbnuts22715)
tires are wearing evenly, like i said it's only going faster when i let go of the wheel.
Old Jul 18, 2005 | 10:00 AM
2G0S0R1's Avatar
New User
Default Re: (mrdeadman)
Brake pads wearing evenly (no stuck caliper?)...
Front wheel bearings noisy at all?
No transmission/differential noises?
Have you had the alignment checked?
Old Jul 18, 2005 | 10:02 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (2G0S0R1)
get an alignment.
Old Jul 18, 2005 | 10:18 AM
mrdeadman's Avatar
They let me pick
it doesn't happen all the time, just when im going 65+ so it's not the brakes, there is no noise coming from the front either, the car only has 56000 miles on it. doesn't a screwed up alignment cause your tires to wear unevenly, mine are fine.
Old Jul 19, 2005 | 06:27 PM
flip b18b's Avatar
sometimes your tires will wear evenly. also with your caliper i had just addresed a similar problem with my teg and my brake caliper war bum when my rotor would heat up it would cause the caliper to grab.
Old Jul 19, 2005 | 06:33 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't happen all the time, just when im going 65+ so it's not the brakes, there is no noise coming from the front either, the car only has 56000 miles on it. doesn't a screwed up alignment cause your tires to wear unevenly, mine are fine.</TD></TR></TABLE>
What condition are your tires in. I had the same problem as you, and I thought I needed an alignment, but I was beginning to need new tires anyway so I bought some and problem solved. The old ones weren't wearing out unevenly either. I don't understand why that worked the way it did but theres no use in looking up a dead horses *** I guess.
Old Jul 19, 2005 | 06:51 PM
jennifermike's Avatar
Default Re: (walker111)
yup<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">get an alignment.</TD></TR></TABLE>
Shirozu
Acura TSX
Jul 4, 2011 12:08 PM
musclehead954
May 26, 2008 07:19 PM
teewhy55
Dec 22, 2004 09:36 PM
true97typer
Nov 20, 2004 05:15 PM
chron1k
Apr 7, 2003 10:39 AM
