cams
Old Jul 18, 2005 | 08:38 AM
Han Solo's Avatar
Default cams
I cant decide what cams to use in my daily driven del sol. Toda spec B or buddy club spec IV. any insight or differences wanted. Thanx
Old Jul 18, 2005 | 10:23 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: cams (jdmdelsolb16)
What is your current setup? I'm just guessing, but you probably have other things you should do before you crack your motor open.
Old Jul 18, 2005 | 12:34 PM
civicgsr19's Avatar
Default Re: cams (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">What is your current setup? I'm just guessing, but you probably have other things you should do before you crack your motor open.</TD></TR></TABLE>
Yea, id start with bolt-ons before you dive into cams, with cams come a certain degree of tuning, and if you start bolting other mods on your car after you've tuned for the cams, then you have to retune, and that can be costly. So your best bet is to plan out what you want to accomplish with your car and start researching.
Just my 0.02
Old Jul 18, 2005 | 05:28 PM
Han Solo's Avatar
Default Re: cams (civicgsr19)
I have most of the bolt on stuff done, intake, headers, exhaust, clutch, flywheel, and im getting ITR pistons and a hondata s200 with my head package. which ill try to tune soon. sorry if my original statement wasnt clear enough.
Old Jul 18, 2005 | 05:39 PM
strsi's Avatar
is it a b16? if so then I believe both cams are too much.
Old Jul 18, 2005 | 05:56 PM
philafelman's Avatar
Default Re: (strsi)
what compression do you want for the car. are you just gonna throw in some p73 pistons and call it a day...or will there be head milling/flat-faced valves, etc....
Old Jul 18, 2005 | 06:36 PM
Han Solo's Avatar
Default Re: (philafelman)
Yea its a b16 and im gonna get buddy club flat valves with my head package. I hope to run somewhere between 11.3-11.5 compression.
Old Jul 18, 2005 | 10:12 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (jdmdelsolb16)
What kind of header do you have? Both those cams are pretty hot, even for the compression you are shooting for.
Old Jul 18, 2005 | 11:16 PM
strsi's Avatar
i think both cams are a little much for a b16 even with that CR. but if i'd have to pick one, I'd go toda
Old Jul 19, 2005 | 07:22 AM
Han Solo's Avatar
Default Re: (rochesterricer)
I have an ITR header and i know both caqms are pretty aggressive but I woint be driving the car that much, just to school and back and for errands
Old Jul 19, 2005 | 07:23 AM
Han Solo's Avatar
Why ask about the header?
Old Jul 19, 2005 | 07:24 AM
ShaunRR's Avatar
HT White Ops
Community Builder
You will want to get a better header, like RMF, SMSP, DTR, etc.
Old Jul 19, 2005 | 09:43 AM
DonF's Avatar
Where is the "other" option?
Old Jul 19, 2005 | 09:48 AM
Han Solo's Avatar
Default Re: (DonF)
what would u suggest?
Old Jul 19, 2005 | 12:50 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Where is the "other" option?</TD></TR></TABLE>
As far as cams or headers?
If you mean cams, I would probably say CTR cams, or maybe BC3+'s. He would be close to the compression we recommend for M22's, but that 11.5 is the bare minimum compression we recommend for that displacement. He would probably be happier with the other two I listed.
Old Jul 21, 2005 | 01:20 PM
Han Solo's Avatar
I decided to get a stroker kit(1.8) from spoon anyway. do u think itd be better than, 11.3 compression
Old Jul 21, 2005 | 01:25 PM
ShaunRR's Avatar
HT White Ops
Community Builder
At 1.8L, the motor should love M22's then.
Old Jul 21, 2005 | 02:24 PM
Han Solo's Avatar
thanks for the input, ill think about it for a while
Old Jul 21, 2005 | 02:50 PM
spoon stroker kit?? damn, obviously money is not an issue here?
Old Jul 21, 2005 | 05:12 PM
Han Solo's Avatar
only 1300 bux cause it uses ITR rods and crank. plus it gets spoon pistons. soo i think its a good deal
Old Jul 21, 2005 | 05:23 PM
sheepey's Avatar
spoon stroker kit is only offered for B16B not b16As. You cant use that kit in b16a block using factory pistons,rods and crank. b16b is a lil taller in deck.
Old Jul 21, 2005 | 07:29 PM
UncleD's Avatar
Default Re: (sheepey)
I'm really not sure why you would spend the $$ on the "Spoon stroker kit." Personally, I would keep you crank and rods, put some rod bolts in it with some PCT pistons, drop some M22's in with RM gen 2 springs and you're golden. That motor with a good header and IM, with the Rm chip will absolutely SCREAM. That would be your quickest budget build right there...damn, insane top end.
Angel4768
May 23, 2011 09:49 PM
HondaIntegraR
65
May 22, 2008 12:54 PM
gurlracer_camille
Feb 4, 2007 08:46 PM
kallmotor
Aug 22, 2004 07:10 AM
