EG Manual pedals won't work in a AT EG?
Old Jul 18, 2005 | 08:13 AM
JDM-EJ1's Avatar
Default EG Manual pedals won't work in a AT EG?
I'm currently doing an auto to manual swap on my EG. I supplied them with a manual pedal assembly out of an EG Hatch that I got from a junkyard (not sure which year, but it was an EG).
I have a 94 EX coupe. The shop told me that those pedals WILL NOT work, how can this be true? I was under the impression that the pedals WILL work with my chassi since it's in the same generation.
Any insight on this would be great! Thanks guys.
Old Jul 18, 2005 | 09:18 AM
5thGenCivicKid's Avatar
Default Re: EG Manual pedals won't work in a AT EG? (JDM-EJ1)
u need 92-95 manual pedals break and gas other wise if you dont you will have to cut the break pedal and the clutch pedal is very close to your break
i did that and it sucked! just get the hole assembly clutch break pedal all from a manual car
Old Jul 18, 2005 | 09:26 AM
JDM-EJ1's Avatar
Default Re: EG Manual pedals won't work in a AT EG? (5thGenCivicKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenCivicKid &raquo;</TD></TR><TR><TD CLASS="quote">u need 92-95 manual pedals break and gas other wise if you dont you will have to cut the break pedal and the clutch pedal is very close to your break
i did that and it sucked! just get the hole assembly clutch break pedal all from a manual car</TD></TR></TABLE>
That's what I did, I gave the shop a manual pedal bracket (clutch, gas, brake) and they're telling me that it won't work with my EJ1.
Bottom line, yes or no.. Will this pedal assembly work with my 94 Civic?
Old Jul 18, 2005 | 10:47 AM
if its from a 92-95 civic yes
Old Jul 18, 2005 | 11:47 AM
HBADGE's Avatar
bump
Old Jul 18, 2005 | 12:01 PM
SAVIOVEGA's Avatar
Default Re: EG Manual pedals won't work in a AT EG? (H-BADGE)
I don't see why the hell it won't fit. I just had to drop the steering column to get them in place
Old Jul 18, 2005 | 01:41 PM
Luserkid's Avatar
Default Re: EG Manual pedals won't work in a AT EG? (SAVIOVEGA)
update for this kid, he had the right pedal assembly but the bracket for the throttle cable wasnt there. broken off or something, but it wasnt there.
This shop sucks super nuts at customer service and explaining what they need to do and why. But everything shoudl be going good now seeing as i havent heard anything since.
Old Jul 18, 2005 | 08:32 PM
93civicsedan's Avatar
Default Re: EG Manual pedals won't work in a AT EG? (Luserkid)
Yea any 92-95 will work. I hope you dont have any problems after you get the car out the shop, seems like theyve been giving you alot of trouble to get the conversion.
mikeyleed
Mar 18, 2018 03:07 PM
RRBNJ
Dec 14, 2007 10:45 PM
dem0nk1d
Jun 7, 2007 11:08 AM
y2kferari
Feb 24, 2007 10:23 AM
