what do you do about car alarms and turbo timers????!!!
Old Feb 17, 2002 | 03:10 PM
14eight's Avatar
Default what do you do about car alarms and turbo timers????!!!
my car alarm wont let me arm it until the car is shut off. has anyone dealt with this problem?? thanks in advance
Old Feb 17, 2002 | 03:27 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: what do you do about car alarms and turbo timers????!!! (14eight)
hook the alarm ignition wire to accesory
Old Feb 17, 2002 | 03:35 PM
dangerzone's Avatar
New User
Default Re: what do you do about car alarms and turbo timers????!!! (turbotypeR)
It works perfectly fine for me. Just set the shock sensor less sensitive you will be fine.
Old Feb 17, 2002 | 05:01 PM
93LSivic's Avatar
Default Re: what do you do about car alarms and turbo timers????!!! (dangerzone)
Or to elaborate on that further, you can hook up the ground of shock sensor to the negative armed out from the alarm. Most will have them, and is usually the wire that goes out to the relay for the starter kill. This way you wont have to worry about a shock sesor that isnt sensative enough to set off the alarm!
Old Feb 18, 2002 | 04:45 AM
25 Year Member
Default Re: what do you do about car alarms and turbo timers????!!! (93LSivic)
if you do that,it will still go off when you arm the alarm.if you want to bypass the shock sensorget a relay and hook 85 to ground,86 to the ignition wire you un hooked the alarm ignition from.cut the red wire of the shock sensor and hook one side to 30 and the other to87a.this will not alow the shock sensor to work with the ignition on or when the turbo timer is on.i manage a stereo/import performance shop and i do them all the time.they work perfectly.
Old Feb 18, 2002 | 05:32 AM
TypeC's Avatar
On my Alarm (DEI, who makes Viper, Hornet, etc) if you hold "I" for 3 seconds, it arms while the car is counting down. I use this to warm up my car in the morning as well.
-C
jay24k
Audio / Security / Video
Aug 18, 2009 04:58 PM
Boostless97Lude
Nov 4, 2005 12:36 PM
Greyout
Jul 24, 2003 06:15 AM
VTEC-DA
Sep 17, 2002 09:47 AM
Weston
Jan 30, 2002 04:01 PM
