Will 99 Civic Shocks fit 95 EG?
I found this.... https://honda-tech.com/zerothread?id=1306499
Anyone have more detail on this topic?
To answer your question yes they will fit, but it requires you to modify the the rear lower control arms. So basically the fronts will fit just fine but you need to grind the metal insert part of the bushing to allow the fork of the shock to fit over the lca. Make sure you grind down both sides of the metal insert evenly otherwise it will speed up the wear and tear of the bushing. Hope this helps
Sprockets
Suspension & Brakes
Nov 30, 2007 08:16 PM
juicedricer
Dec 11, 2002 01:44 AM
