Car wont rev up!
Old Jul 18, 2005 | 05:27 AM
Bizarre's Avatar
Default Car wont rev up!
Alright well my car started showing my a code 17 a few days ago. My problem is that it will not let me rev over 1700rpm. When I am not moving I can rev the to basically whatever I want even the orig rev limiter but as soon as I start moving it wont let me rev past that. Im a getting code 17 and code 9 (I was getting this before I had this problem). Its weird though, when it hits about 1700 it doesn't act as a rev limiter. It just stops the throttle input and then once it revs down abit it will let me speed back up again kind of like a speed limiter. Also when I hit about 1700 rpm the car will start to jerk back and forth and wont go over it. I tried checking the the speedo cable and its fine. Im going to replace the vss now but I wanted to hear if anybody had any input into this. Might it be something else that can cause this? Btw this is a 90 dx that was converted from dual point to multipoint with a b16 if that helps.
Update 2:
What lets the ECU know what speed the car is travelling at? I noticed that their are no wires off the VSS, therefore the ECU is not reading from the VSS. Does the ECU read from the cluster? The cluster was swapped out for a newer cluster and wiring might have gone bad over time. Or does the ECU read off of a sensor on the wheel? Car is not equipped with ABS incase that helps.
Also I believe I might have ruled out the VSS because the speedometer reads and works fine. I have disconnected the speedo cable before and all it does is run in limp mide with no vtec, but speeds up well passed my problem.
Old Jul 18, 2005 | 06:27 AM
Bizarre's Avatar
Default Re: Car wont rev up! (Bizarre)
I thought this might have been cause by a bad ecu, tried another still the same problem which its really leading me to believe its what ever is sending the signal to the ecu is not doing it properly.
Efwithhatch
12
Oct 23, 2012 07:41 PM
spens 91 Ef
Aug 19, 2010 05:01 AM
89civichb
Oct 18, 2007 11:30 AM
94b16teg
Nov 7, 2006 07:01 AM
Bizarre
Jul 27, 2005 08:48 AM
