Shaving letters off Valve Cover
Old Jul 18, 2005 | 04:39 AM
DFW's Avatar
DFW
Default Shaving letters off Valve Cover
Searched and only found on topic on this. Someone said that they sanded their letters off with 150 grit. Anyone else can confirm this or another way of going about it?
Old Jul 18, 2005 | 04:41 AM
eL's Avatar
eL
That's gonna take a lot of sanding. Please, whatever you do, PAINT the valve cover again. Unpainted VC's look like **** unless totally polished.
Old Jul 18, 2005 | 04:43 AM
DFW's Avatar
DFW
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">That's gonna take a lot of sanding. Please, whatever you do, PAINT the valve cover again. Unpainted VC's look like **** unless totally polished.</TD></TR></TABLE>
I know this I was guna polish it takes a lot more work than I thought. So I'm probably guna end up paiting it back to stock black wrinkle paint. I was thinking of using a belt sander but it's still guna be a of sandpaper.
Old Jul 18, 2005 | 04:46 AM
menkio's Avatar
Default Re: (DFW)
just get a die grinder, shouldn't take more than 5 mins
Old Jul 18, 2005 | 05:05 AM
DFW's Avatar
DFW
Default Re: (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">just get a die grinder, shouldn't take more than 5 mins</TD></TR></TABLE>
Now, anyone wana let me borrow one?
Only thing I have that I can think of that can do the job is a belt sander
Old Jul 18, 2005 | 05:08 AM
JIDUM_Undercover's Avatar
i shaved ym type-r valve cover completely with a diegrinder didnt even take 5 minutes i know you know somone who has one ? If not go to harbor freight pay 25 bucks for one and borrow a comprressor.
Old Jul 18, 2005 | 05:12 AM
DFW's Avatar
DFW
Default Re: (JIDUM_Undercover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JIDUM_Undercover &raquo;</TD></TR><TR><TD CLASS="quote">i shaved ym type-r valve cover completely with a diegrinder didnt even take 5 minutes i know you know somone who has one ? If not go to harbor freight pay 25 bucks for one and borrow a comprressor.</TD></TR></TABLE>
I have a compressor already. But I'll ask around today.
Btw, would this do the job? http://www.harborfreight.com/c...44716
Edit: Checked the site out and found this http://www.resellerratings.com/seller4585.html Seems like it's not very reputable..
Old Jul 18, 2005 | 05:47 AM
macDelli's Avatar
Default Re: (DFW)
be a man use a screwdriver and chip that **** off...jk i did this and it looks like shiiittt my opinion is the 150grit itll come out quite nicely
Old Jul 18, 2005 | 05:52 AM
DFW's Avatar
DFW
Default Re: (macDelli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macDelli &raquo;</TD></TR><TR><TD CLASS="quote">be a man use a screwdriver and chip that **** off...jk i did this and it looks like shiiittt my opinion is the 150grit itll come out quite nicely </TD></TR></TABLE>
Hahah. How long did that take you?
Old Jul 18, 2005 | 05:55 AM
huepowered's Avatar
Default Re: (DFW)
dremel drill? bet you lots of people have these laying around
Old Jul 18, 2005 | 06:04 AM
jmayhew's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">whatever you do, PAINT the valve cover again. Unpainted VC's look like **** unless totally polished.</TD></TR></TABLE>
i disagree....
raw metal look for me all the way....**** paint or polish
Old Jul 18, 2005 | 06:11 AM
DFW's Avatar
DFW
Default Re: (jmayhew)
Asked the neighbor and he has a die grinder
So I'll try that out in couple of hrs.
Old Jul 18, 2005 | 06:16 AM
Drag_On's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Asked the neighbor and he has a die grinder
So I'll try that out in couple of hrs.</TD></TR></TABLE>
Post results.. This is my next project
Old Jul 18, 2005 | 06:31 AM
DFW's Avatar
DFW
Default Re: (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">Post results.. This is my next project</TD></TR></TABLE>
Sure will
Old Jul 18, 2005 | 07:56 AM
DFW's Avatar
DFW
Default Re: (DFW)
Great, die grinder doesn't work.
I guess I'll try the belt sander for now and if that doesn't work I'll find someone with something.
Old Jul 18, 2005 | 08:30 AM
herde1724's Avatar
just be careful when you use a die grinder that you don't go too deep in places otherwise ur gonna be usin filler......... i'll post some pics of mine when i get home i use a sanding disk on my angle grinder worked great then sanded with 400 to prep for the paint
Old Jul 18, 2005 | 02:20 PM
DFW's Avatar
DFW
Default Re: (herde1724)
Here it is...Still need to sand it smooth and then prep for paint. But paint might be awhile need to order some wrinkle paint and some time to do it. I grinded a lil too much on some spots but I just used the belt sander after everything smooth everything out using 80 grit.
Oh btw, don't even try to sand it with anything. Defently need a die grinder anything of that kind. Took like 2 minutes at most to grind off the letter and sand it down.
Before
After
Modified by DFW at 7:15 PM 7/18/2005
Old Jul 18, 2005 | 02:50 PM
Options's Avatar
All Secrets Known
Default Re: Shaving letters off Valve Cover (DFW)
Not relevant to the question at hand, but I thought this pic was pretty cool.
Old Jul 18, 2005 | 02:54 PM
DFW's Avatar
DFW
Default Re: Shaving letters off Valve Cover (Options)
^That's what made me get up and do it. Always wanted to but never really really wanted to
Old Jul 18, 2005 | 02:57 PM
Dstretch33's Avatar
Damn looks hard
Old Jul 18, 2005 | 04:08 PM
BlUeDC2nEr's Avatar
Old Jul 18, 2005 | 04:14 PM
DFW's Avatar
DFW
Default Re: Shaving letters off Valve Cover (BlUeDC2nEr)
^What method did you use? Die grinder? Looks smooth
Old Jul 18, 2005 | 04:24 PM
DFW's Avatar
DFW
Oh btw, where can get VHT wrinkle paint? Just any auto part store? I checked summit and was like 18 bux plus another 20 cuz its 'hazordious'.
Old Jul 18, 2005 | 04:25 PM
ecahatch's Avatar
Senor Miembro
Default Re: (DFW)
grinder/ 1500 grit....
Old Jul 18, 2005 | 06:20 PM
omg_miiiike's Avatar
Default Re: (DFW)
i just did mine after reading this thread. i used a sander and 80 grit and took me 10 minutes..
