Suspension & Brakes Theory, alignment, spring rates....
New springs - rear (Quick question)
Old Jul 18, 2005 | 03:40 AM
Ax3l's Avatar
Default New springs - rear (Quick question)
Hey,
Is there a way to take off the old/put on the new springs up rear on my 97 civic coupe without loosening the shock from the lower control arm? Is it possible to do if i just remove the upper mounting points? My LCA bushing/bolt is totally stuck...
I am just swapping the springs, not the shocks.
I've got spring compressors.
I have searched, but all the info is on how to remove it all (springs and shocks), and not just putting on new springs.
-Thanks.
Old Jul 18, 2005 | 06:28 AM
00R101's Avatar
Default Re: New springs - rear (Ax3l)
No
Old Jul 18, 2005 | 09:24 AM
Tyson's Avatar
if only the shock bolt/bushing is stuck, you could conceivably remove the lca with the shock and proceed as normal.
Old Jul 18, 2005 | 12:53 PM
solareclipseauto's Avatar
Default Re: New springs - rear (Tyson)
yeah just remove the whole lca and go from there
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
harryr34
Suspension & Brakes
Jun 28, 2006 01:27 PM
STDClayton
26
May 18, 2006 04:44 AM
dcrbin22
Jan 4, 2005 07:32 PM
Renegade
Jun 15, 2002 11:01 PM
