b20 build. need opinions..
im planning to setting up a b20vtec build by next month...need opinions...
block:
rods- i found eagle rods to be the cheapest....300$ for the set...any negative feedback on these? I or H beam?
pistons - i'm sticking with stock sleeves, and i dont plan to rebore. so im thinking 84mm super dupers from IB. (will be runing on 93octange). what do you guys think? or shelf stock pistons will do the same?
head: (i have these already)
s2s2 cams, rm valvetrain, supertech flat valves...
tuning is done through hondata....is it a must to have aftermarket sleeves on a b20? should i upgrade headbolts also? thanks...
if you are a seller with parts that i need, please send me a pm. thanks..
block:
Spoon Si
Dec 2, 2003 05:26 AM
ridestrt
12
Nov 3, 2003 08:03 PM
