I need Help whick cams should i use for a stock Bottom End?
Ummm, we need a little more info than that. I dont know maybe you should let us know what bottom end you're referring to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PepDiesel »</TD></TR><TR><TD CLASS="quote">Its for a 2000 SI with stock pistons and rods , id like to keep it a Daily Driver</TD></TR></TABLE>Buddy club 3+ with aftermarket valvetrain.
Do a little bit of researching on here and you will find out a whole hell of a lot of information...Search Skunk2 Cams, Buddy Club Cams, Jun Cams, Toda Cams...list can go on. I can tell you this...With Skunk2 Stage 1's and Toda Spec A's, it is not a must to upgrade valve springs and retainers as long as you arent revving past stock redline...Also, Toda Spec A's have the most lift and duration of just about any "entry-level" cam out there although pricy! Search around and you will find answers...Figure out what your power goals are and go from there...
gsrwpower
Mar 21, 2006 05:38 PM
