What compression will I need?
What compression will I need to run this spec camshafts?
Advertised Duration Int- 311 mid Exh-308 mid
Duration @ .050" Int- 255 mid Exh-248 mid
Gross Lift w/1.55 Int- 468 mid Exh-467 mid
thanks
thanks
Ah, those are the stage 2 cams right?
I'm using Crower stage 3's and will be running 12.5:1 compression.
You ought to check the "official" Prelude camshaft thread, I believe there are a few guys running the stage 2 cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep »</TD></TR><TR><TD CLASS="quote">dude.. not to be a dick or anything but asking this question is like asking what toothpaste to use on my toothbrush.</TD></TR></TABLE>
No need to be an ***. Just cause maybe u have more exp. than the guy doesnt mean he cant ask. Reason why this is a FORUM. good day - alex
Ya because that makes sense.....
Im not a asking a brand specific question, Im asking what compression will I need, because I no with chevys what compression I will need for a camshaft. I just think this stage 2 camshaft will need higher then stock compression to be worth while
i got Skunk 2 Stage 2's cams, retainers and springs in recently....should have done more research....I need 11:1 compression to fully take advantage of these cams...will be putting in JDM
11:1 pistons in soon with upgraded rods...
DarkSolPR
34
May 29, 2005 03:37 AM
