electrical help on EG
sometimes when im driving and i have my lights on and i signal, once i push the signal all the lights flash off than go back on, but it will only do it with the first flash than the lights stay on
Where should i start to look for this,
Thanks
Thanks
sorry maybe i should have been more specific
THe DASH LIGHTS flick off than go back on when i signal, almost like a power surge or something
What may be happening is all your lights (not just the dash lights) may be shutting off as you're pressing the signal lever. Sounds like a short or loose connection in your multifunction switch (signal lever switch) inside the steering column or the headlight switch on the actual lever itself.
well its only the dash lights that flash None of the Exterior ones do, but im goin to check what u said, i had a gsr dash before but i put it back to stock, maybe something is touching somewhere ill start there, any other opinions will be apreciated
You might wana see the ground wire? it happend to me aswell. But it only happend when i would press the brakes. The turn signal would not work at all...
so check out the ground !!!
cgjarvis
10
Aug 7, 2016 12:22 PM
akacoke
15
Sep 22, 2011 05:21 PM
AMChev
Oct 14, 2003 05:16 AM
