89 and 91 crx headlights need quick response please>
Old Jul 17, 2005 | 07:51 PM
djsire's Avatar
Default 89 and 91 crx headlights need quick response please>
are they interchangable? the head lights and tail lights.
Old Jul 17, 2005 | 07:54 PM
Bunger's Avatar
Default Re: 89 and 91 crx headlights need quick response please> (djsire)
Tails, yes... unbolt the old and put in the new... headlights, kinda... you need to change other parts also.
Old Jul 17, 2005 | 07:59 PM
92integra_gs's Avatar
taillights you can swap 88-91
headlights you need to get the right year 88-89 or 90-91 ...the difference is in the fender and corner light mounts...
Old Jul 17, 2005 | 08:08 PM
Losrocket_'s Avatar
Default Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">
headlights you need to get the right year 88-89 or 90-91 ...the difference is in the fender and corner light mounts... </TD></TR></TABLE>
Actually the headlights are the same its just the mounting of the cornerlights that are different. An '88-89 headlight will work in a '90-91 and vice versa without any problems. Essentially all '88-91 Civic HB/sedan/CRX headlights are interchangeable.
Old Jul 17, 2005 | 08:20 PM
djsire's Avatar
Default Re: (Losrocket_)
cool thanks guys!!!1
Old Jul 17, 2005 | 08:25 PM
Kryogen's Avatar
to get the 88-89 Headlights to work on the 90-91's...seeing as how people said it will work and not told you how......You need to swap the Headlight buckets from the 90-91 to the 88-89...Thats where the Cornerlight screws to.
Old Jul 17, 2005 | 09:32 PM
crx-treme's Avatar
Default Re: (Kryogen)
listen to kryogen hes right. i just put my oem headlights back in, (90) and found out i have one 90 headlight and one 88 or 89 headlight, both with the 90 buckets. the 90-91's have moisture vents in the top, the 88-89's do not. so i have one headlight with condensation in it and the other doesnt.
Ralph Wiggum
May 18, 2006 06:32 PM
Vovchandr
Feb 15, 2006 08:37 PM
HmgLauj69
23
May 14, 2005 06:53 AM
Scantron
Mar 14, 2005 02:53 AM
B.S._TURBO
Nov 15, 2004 02:50 PM
