can i use 2 walbro 255 gph intake pumps or 1 paxston fuel pump 700 hp
Old Jul 17, 2005 | 06:53 PM
dphonesavang's Avatar
Default can i use 2 walbro 255 gph intake pumps or 1 paxston fuel pump 700 hp
i would like to keep my factory fuel tank in the car but need lots of fuel for my 1200cc inj. i have a paxton pump good for 800hp. but puting after in tank will retrick the flow. i want to use to walbro 255 gph in tanks pumps side by side and new fittings on to of pick up with 8 an fittings 1/2" alum fuel line front to back. oh yea 3/8 off pumps split into a y 1/2" out. use old sending line for return in tank. any tryed this? i saw an supra do this in sport compact mag. will 2 intake pumps suport 1200cc inj pushing 700 to 800hp? thanks for you time!
Old Jul 17, 2005 | 07:14 PM
paulzy's Avatar
why not run a fuel sump off the stock tank and use only the paxton with new lines?
Old Jul 17, 2005 | 11:15 PM
Default Re: (paul vang)
yea , but is it legal for comp rules? or i would do that!
Old Jul 18, 2005 | 06:42 AM
evilone's Avatar
Default Re: (dphonesavang)
2 255lph will definitely support the hp......but if you have 1 pump go bad you might not know until its to late
Old Jul 18, 2005 | 07:02 AM
ZEX Man's Avatar
Default Re: can i use 2 walbro 255 gph intake pumps or 1 paxston fuel pump 700 hp (dphonesavang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dphonesavang &raquo;</TD></TR><TR><TD CLASS="quote">i would like to keep my factory fuel tank in the car but need lots of fuel for my 1200cc inj. i have a paxton pump good for 800hp. but puting after in tank will retrick the flow. i want to use to walbro 255 gph in tanks pumps side by side and new fittings on to of pick up with 8 an fittings 1/2" alum fuel line front to back. oh yea 3/8 off pumps split into a y 1/2" out. use old sending line for return in tank. any tryed this? i saw an supra do this in sport compact mag. will 2 intake pumps suport 1200cc inj pushing 700 to 800hp? thanks for you time!</TD></TR></TABLE>
I made this exact set-up for my race car, except they were the external style Walbro 255 high-pressure pumps. They have the same pump internals as the in-tank models. The two pumps, at 50 psi, through a single -6 AN line, flowed enough fuel to support 1050HP at 13.2 VDC.
Old Jul 18, 2005 | 09:07 AM
turtle-eg's Avatar
Default Re: can i use 2 walbro 255 gph intake pumps or 1 paxston fuel pump 700 hp (ZEX Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEX Man &raquo;</TD></TR><TR><TD CLASS="quote">
Did you have to sump the tank to run the external pumps? Mind sharing how you did it? Inline or parrallel pumps?
Old Jul 18, 2005 | 09:35 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dphonesavang &raquo;</TD></TR><TR><TD CLASS="quote">yea , but is it legal for comp rules? or i would do that!</TD></TR></TABLE>
Which class do you plan on competing in? As far as I know, you can run an external pump with a sumped stock tank in Turbo4 and SFWD only states that you can't run a fuel cell, so a sumped tank would work. I'm sure the other T4/SFWD guys would chime in.
Just keep it simple.
Old Jul 18, 2005 | 09:47 AM
Turbocivic94's Avatar
Default Re: (Finest)
I ran full-race sump with external pump and -8an to fuel rail and use the feed for return.
Old Jul 18, 2005 | 10:33 AM
Default Re: (Turbocivic94)
thanks for the input. next ? did you guys weld the sump on the tank or bolt with gasket? i can get a new tank can cut and weld a sump on it. what do the rules say? do you have to weld the sump?
Old Jul 18, 2005 | 10:46 AM
You just weld it. U dont have to cut anything, just dril holes in tank where its going to be welded. Full-Race sump comes with instructions.
Old Jul 18, 2005 | 11:40 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">You just weld it. U dont have to cut anything, just dril holes in tank where its going to be welded. Full-Race sump comes with instructions.</TD></TR></TABLE>
Full-Race has a nice simple setup. Contact them for instructions/pictures.
Old Jul 18, 2005 | 11:49 AM
Flamenco-T's Avatar
You need to make sure that the Paxton is a puller pump if you're not running a sump. I doubt it though. I am running the Bosch Pump, it is a puller pump and I am not running a sump. I made a custom fuel pickup from the stock factory tank cover and I installed the Bosch on the outside of the tank.
We're pushing almost 800 hp with it and still runs fine and I have even made a pass at the track with the fuel light low light on and never leaned out at all.
I helped Jason Hunt with the setup as well on his CRX and now, well...low 9's is in the works... hahhaha, I sure hope so
Stan
Old Jul 18, 2005 | 03:04 PM
Default Re: (Flamenco-T)
well i was going to do that, but if you run a tube with a sack on in the tank how are you going to get the fuel up and back down again? will the pump suck enough to pull the gas up and out?
Old Jul 18, 2005 | 03:21 PM
jpenman50's Avatar
The two pumps in the tank will work for lots of horsepower. I am running 2 285 holly pumps and making plenty of power. The nice thing about this setup it is its not load at all
Old Jul 19, 2005 | 12:22 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dphonesavang &raquo;</TD></TR><TR><TD CLASS="quote">well i was going to do that, but if you run a tube with a sack on in the tank how are you going to get the fuel up and back down again? will the pump suck enough to pull the gas up and out?</TD></TR></TABLE>
I used the bosch pump which is a puller pump. Aeromotive, paxton are all pusher pump. It can only push what's collected on the inlet side. Bosch can actually pull it from any source.
We sell the bosch pump for $ 300
Old Jul 19, 2005 | 06:00 AM
ZEX Man's Avatar
Default Re: can i use 2 walbro 255 gph intake pumps or 1 paxston fuel pump 700 hp (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">
Did you have to sump the tank to run the external pumps? Mind sharing how you did it? Inline or parrallel pumps?</TD></TR></TABLE>
I had a fuel cell. The pumps were run parallel and came together with a -6AN Y fitting.
Old Jul 19, 2005 | 06:36 AM
Damn, I wish I knew this before cause I just did my fuel setup
Old Jul 20, 2005 | 04:17 PM
so can i run my paxton pump under the car in the back? in the sfwd class?
Old Jul 20, 2005 | 04:47 PM
Drag-Accord's Avatar
I run twin walbro 255 high pressures intank for my setup with a -6an Y fitting to a single -6an line. Works fine, and i haven't had a problem so far.
Old Jul 20, 2005 | 06:52 PM
paulzy's Avatar
yes you can
Old Jul 24, 2005 | 06:40 PM
eg:R's Avatar
some people run performance inline and intank fuel pump together
Old Jul 25, 2005 | 09:38 AM
Flamenco-T's Avatar
Default Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">some people run performance inline and intank fuel pump together</TD></TR></TABLE>
let me put it in a different way, would you use your garden hose to feed a fire hydrant hose ? essentially that's what the above scenario is. You're using the smaller pump to drive the bigger pump. It's better to remocve the smaller one and run the bigger one.
stan
Old Jul 25, 2005 | 02:50 PM
paulzy's Avatar
stan, is that the same bosch pump that endyne sells??
Old Jul 27, 2005 | 12:52 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">stan, is that the same bosch pump that endyne sells??</TD></TR></TABLE>
Yes
hondaapi
May 13, 2010 11:39 PM
maddcrx
May 9, 2008 07:29 PM
bossman032
18
Jun 1, 2004 08:16 PM
